Megatron-UK
posted on 15/1/07 at 12:03 PM |
Yamaha R1 throttle position sensor -plug-
Hi folks, I'm needing a Yamaha R1 (98/99 carb model) throttle position sensor /plug/ to finish plumbing the megajolt on my Pinto. The carbs came
with the TPS, but no plug.
Anyone got a plug spare that they'd be willing to part with for a reasonable offer?
I'm also needing the wiring info for the 3 wires from the tps to the megajolt unit. The wires from the ecu are marked, but I'm not sure
what leads are what on the TPS!
smart51
posted on 15/1/07 at 12:27 PM |
I guess you'll either have to cut one from a loom or try and get the parts from a Yamaha dealer. tell him that your plug is broken and you need
to ft a new one. Yamaha spares are quite reasonably priced.
As for the wires, Yellow is the pot position, blue is supply voltage (5V?) and Black/blue is ground. Not too helpful huh?
Nick Skidmore
posted on 15/1/07 at 12:32 PM |
I have one from an FZR1000 Thunder Ace,
if it's the same you can have it for a fiver.
I usually convert them to a rubber Amphenol connector from RS.
Nick
Megatron-UK
posted on 15/1/07 at 12:39 PM |
Nick
Hi Nick... I would guess that it's fairly likely to be the same - it's a pretty standard 3 pin type plug after all.
Have you got a paypal account I can send the money to?
Dusty
posted on 15/1/07 at 01:48 PM |
These people do all sorts of weird and wonderful Japanese bike plugs.
Dataspares Worth putting in your links page if you have a bike engine.
[Edited on 15/1/07 by Dusty]
