givemethebighammer
posted on 18/1/07 at 05:57 PM |
coiled cable
coiled cable
Does anyone know where I can get a small quanity of coiled power cable something like below?
I only really need 2 core cable as it's for the front of the car when I need to take the nose cone off and disconnect the indicators. I thought
coiled cable would be neater than the length of straight stuff I have fitted at the moment.
thanks
![](/galpreviews/a488002-coiled cable.JPG) ![Rescued attachment coiled cable.JPG](/gallery/a488002-coiled cable.JPG) Rescued attachment coiled cable.JPG
graememk
posted on 18/1/07 at 05:59 PM |
wouldnt a plug and socket be better?
something like you get on an electric lawnmover or hedge trimmer?
[Edited on 18/1/07 by graememk]
givemethebighammer
posted on 18/1/07 at 06:05 PM |
I have some of those radio controlled car power connectors on the current straight cables. The problem is that with the nose cone fitted the distance
between where the indicators are mounted and where the cable comes out of the loom is very short. However to be able to get the nose cone off (to be
able to disconnect the cables) the cable needs to be much longer, hence the coiled cable idea.
[Edited on 18/1/07 by givemethebighammer]
zetec7
posted on 18/1/07 at 06:16 PM |
The true "locost" way would be to use the cord off an old blow drier! Two poles, will take plenty of current, and cheap!![](/images//smilies/bigsmile.gif)
http://www.freewebs.com/zetec7/
Richard Quinn
posted on 18/1/07 at 07:41 PM |
Rs Components
posted on 18/1/07 at 07:45 PM |
Don't maplins do them? I also seem to remember seeing them on Flebay (I wanted coiled signal cable for an intercom unfortunately)......
Otherwise you can get coiled guitar leads- think they're 3 core....
ch1ll1
posted on 18/1/07 at 08:40 PM |
you could always pull you old mans headphones apart
ayoungman
posted on 18/1/07 at 08:44 PM |
Yep coiled audio leads will be OK. They are up to handling the power. 10 amp max tho'
"just like that !"
gazza285
posted on 18/1/07 at 10:39 PM |
It's microphone leads that are three core, guitar leads are two core.
mike4444244
posted on 18/1/07 at 11:06 PM |
hi
vehicle wiring products will have them..
Vehicle wiring products
No one working on cars should be without this catalogue they are very helpful too!
mike
110 Defender
vorn
posted on 19/1/07 at 02:42 AM |
dont laugh but I have made some at work by winding the wire around a piece of steel and putting it in the oven at a low temp (think it was about
70' ) let it cool and taken off the steel , It worked well .
Now thats locost !!!!
[Edited on 19/1/07 by vorn]
