Author: Subject: Aussie single seater
Wadders
posted on 20/1/07 at 09:26 PM Reply With Quote
Googled rose jointed wishbones and this popped up.
http://www.werple.net.au/~iwd/openwheeler/specs.html
ChrisGamlin
posted on 20/1/07 at 09:49 PM Reply With Quote
Wouldnt want to have a front end crash in it though would you!
Ivan
posted on 21/1/07 at 07:35 AM Reply With Quote
Did you look further on the site
"750cc watercooled 8 cylinder, 90 degree vee configuration, bore and stroke 56 x 38mm, 'Flat' (180) crankshaft design, 6 speed close ratio cassette-style gearbox, 4 valves per cylinder, 17,000 rpm redline (race motors 19,000rpm), 120 kW power output projected. "
He also produces a 1000cc version - Imagine how cool that would be in a BEC - 17000 revs past Mr Plod
ChrisGamlin
posted on 21/1/07 at 04:27 PM Reply With Quote
Originally posted by zilspeed
Do you think it's any worse than most spaceframe single seaters ?
Apart from the usual nosecone which does nothing for crash protection ?
Maybe no worse than 20/30 year old spaceframe single seaters, but significantly worse than current designs IMHO.
Ferrino
posted on 21/1/07 at 04:36 PM Reply With Quote
That thing looks incredible - the view from the cockpit must be amazing - never miss another apex!
Mr Clive
posted on 21/1/07 at 10:12 PM Reply With Quote
From what I can see, the front bell cranks operate on either end of a single shock.
How well could that perform? it looks a lot lighter/simpler than two shocks but how much would it compromise the handling?
posted on 21/1/07 at 10:21 PM Reply With Quote
there are some repercussions like different roll resistance etc. Its been discussed in the past but since i cant remember what the system is called, i cant search for it!
Wadders
posted on 21/1/07 at 11:16 PM Reply With Quote
Joel you seem to have an echo at the mo
Mr Clive
posted on 21/1/07 at 11:56 PM Reply With Quote
Its a transverse monoshock.
I found the previous discussion you mentioned here http://www.locostbuilders.co.uk/viewthread.php?tid=22631.
BusaLoco
posted on 22/1/07 at 01:45 AM Reply With Quote
Nice stuff but check out the Dysdale V8
Great discussion but check out their main page and the sound bite of that amzing
750 cc V8
