New Topic New Reply
Author: Subject: ERW RHS seam position
tigris
posted on 25/1/07 at 02:28 PM Reply With Quote
Is there any optimal way to position the seam in welded tubing in a spaceframe?
Ivan
posted on 25/1/07 at 02:47 PM Reply With Quote
In general terms - No - unless the tube is in bending (which they shouldn't be) then place it in the neutral axis.
But as very few tubes are in bending in a spaceframe put it where it can't be seen for best aesthetics.
TheGecko
posted on 25/1/07 at 02:59 PM Reply With Quote
Make sure you don't end up with the seam in a face you'll later want to drill for rivets as it can be a bugger to drill through.
D
carlgeldard
posted on 25/1/07 at 06:14 PM Reply With Quote
Can you post a picture of the box section as ERW should not have a seam and I'm a little confused.
posted on 25/1/07 at 07:16 PM Reply With Quote
It's the side with the dark line down the middle of it on the tubing I used, very easy to spot. As for aesthetics, you won't see it when it's got a coat of paint over it.
meany
posted on 25/1/07 at 07:25 PM Reply With Quote
D
oh poo.....i forgot about that
posted on 25/1/07 at 07:47 PM Reply With Quote
someone once recommended that the seam be put at the bottom to help lower the centre of mass!
t.j.
posted on 26/1/07 at 12:20 PM Reply With Quote
I would prefer them at top.
When mister rust is looking for the weekest spot.
But at the end i think: it doesn't make a difference
posted on 26/1/07 at 12:27 PM Reply With Quote
ERW certainy does have a seam, caused by the edges of the material being welded together. The seam is most obvious as a ridge when looking inside the tube, but on a new tube is shown as discolouration on the outside. If the tube has been sanded down to remove surface rust etc. the seam can be harder to see from the outside.
Gav
posted on 26/1/07 at 12:33 PM Reply With Quote
hehe i rememeber that one and was going to quote it but you got it in first
New Topic New Reply
