New Topic New Reply
Author: Subject: Distributor shaft
cmalc
posted on 14/2/07 at 12:50 PM Reply With Quote
Distributor shaft
Hello
Help, I am stuck.
I am building an Indy. I have been advised by a main ford dealer to contact you guys about my probelm.
During my build I broke the plastic distributor shaft on the front of the engine with the hoist (grrr) anyway I contacted fords for the part but the leadtime is months which means my car is stood idle...I need a distributor shaft for the 1.8cvh, can anyone advise where I can get one (already tried the local scrappies and the onese on the interweb). Has anyone got one going spare?
Malc
Bluemoon
posted on 14/2/07 at 01:33 PM Reply With Quote
You should find one on hear as most don't fit the 1.8cvh motor (but I am!)...
How are you doing the engine mounts, any pics?
Dan
[Edited on 14/2/07 by Bluemoon]
cmalc
posted on 14/2/07 at 02:37 PM Reply With Quote
I got them done. Modified the pinto ones from MK which cam with the kit. But... since then i have fitted a Westfield exhaust manifold which clashes with the mount so now I am currently making one to fit, hopefully by the end of week work permitting.
Malc
greggors84
posted on 14/2/07 at 03:03 PM Reply With Quote
Have you tried Burton? Link
They might have them in stock, if so they will get it out within a couple of days. Best to give them a call as their site might not list it in an obvious place.
Chris
The Magnificent 7!
davidwag
posted on 14/2/07 at 06:01 PM Reply With Quote
Distributor shaft?
Do you mean rotor arm? If so you can probably get one from a motor factor
Davidwag
auzziejim
posted on 14/2/07 at 06:02 PM Reply With Quote
give h+h ignition solutions a ring, very helpful and will sort you out better than ford ever could
james
DarrenW
posted on 15/2/07 at 02:13 PM Reply With Quote
Sorry i dont have the part you need but try linking your request to the wanted section just in case someone else has one and doesnt always read the MK section.
New Topic New Reply
