Author: Subject: Distibutor shaft for ford 1.8cvh
cmalc
posted on 15/2/07 at 02:29 PM Reply With Quote
I need a disributor shaft for the 1.8 cvh engine. Unfortunatly I broke mine when I was dropping the engine into my Indy.
i have tried scrappies etc but no luck. The main dealer (fords ) can order one but it will take months meanwhile I am stuck.
can anyone help?
Malc
DarrenW
posted on 15/2/07 at 02:42 PM Reply With Quote
Are you referring to the steel centre shaft that takes the drive from the block up to the rotor arm?
Do you have a pic of the bit that is broken?
I know on Pinto's there are Lucas and Bosch dizzys used, so if that i sthe case on CVH's it could be worth stating exactly what dizzy yours is (sometimes the colour of the dizzy cap is a give away).
Darren.
posted on 15/2/07 at 03:17 PM Reply With Quote
CVH distributor is on the end of the camshaft, not from the block.
cmalc
posted on 15/2/07 at 04:14 PM Reply With Quote
Yes its a plastic shaft with a steel insert which bolts to the front of the cam pulley. Thats why it is broken as its only made of plastic.
Malc
DarrenW
posted on 15/2/07 at 04:20 PM Reply With Quote
ooops, sorry.
Does this help or have i dug myself deeper??
http://cgi.ebay.co.uk/CVH-Distributor_W0QQitemZ230091809092QQihZ013QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
GMS capri spares tend to do a lot of Ford spares and do all of the trade stands at the major shows.
http://www.gmscaprispares.co.uk/
Ive dealt with them myself and their place is an aladdins cave of bits, quite amazing what they stock sometimes. Highly recommended.
jollygreengiant
posted on 15/2/07 at 04:41 PM Reply With Quote
Malc
You've probably already tried, but, scrappies are likely to be your best bet. I know the bit you mean, its the bit you clip the rotor arm onto under the clip on cap, and yes they are a bit fragile if not pampered properly. You also have to be a bit careful when doing it up, just incase your socket slips, then oops.
And no I haven't got one.
[Edited on 15/2/07 by jollygreengiant]
big_wasa
posted on 15/2/07 at 07:33 PM Reply With Quote
How bad is it broken ? Most I have seen have one clip broken and still run fine.
posted on 15/2/07 at 07:56 PM Reply With Quote
The only reason I knew was my nephew had one and it broke but we glued it together and it ran fine for 3 years till he scrapped it.
