Author: Subject: harnesses
arcoavon
posted on 2/3/07 at 06:48 PM Reply With Quote
harnesses
i spoke to tiger yesterday and was told that the avon will not pass sva with 4 point harness fitted, can anyone hopefully tell me different, thanks.
nitram38
posted on 2/3/07 at 07:10 PM Reply With Quote
Minimum required is 3 points for sva.
Maybe the harnesses are turn buckle type releases instead of the same as your tintop?
andrew.carwithen
posted on 2/3/07 at 07:13 PM Reply With Quote
The standard 4-point harness upper mounts in the rear top chassis rail are too low to pass SVA.
I have got round this (hopefully!) by obtaining a modified Tiger rollbar with an additional bar welded across it (where the mounts for standard three-points were.) This bar now houses the welded threaded tubes for the top harness mounts.
Andy.
DaveFJ
posted on 2/3/07 at 07:18 PM Reply With Quote
The problems as I see them are
1, the Tiger supplied 4 point harnesses aren't e marked (so I understand)
2, the mounting points for 4 point harnesses are too low. the SVA restrictions are measured from the seat base.
HTH
Dave
carlgeldard
posted on 2/3/07 at 07:51 PM Reply With Quote
Photo 11 say's it all. If they are E marked you'll be fine it's the height of the mounting thats the problem.
Carl
nitram38
posted on 2/3/07 at 08:30 PM Reply With Quote
Why don't they sort this out if they are the manufacturer?
ayoungman
posted on 2/3/07 at 08:55 PM Reply With Quote
I'm fitting 3 point for sva then swopping them out afterwards.
"just like that !"
soggy 3
posted on 3/3/07 at 12:13 AM Reply With Quote
Just when i think i have sorted all the problems another one cropps up
How much higher do they need to be?
How easy are 3 point belts to get hold of which make of car would fit?
[Edited on 3/3/07 by soggy 3]
Rudy
posted on 3/3/07 at 07:20 AM Reply With Quote
If 4 points is not ok for SVA, this means it is not safe too!!!
I bought 4 point last week
Sorry about my English
andrew.carwithen
posted on 3/3/07 at 08:03 AM Reply With Quote
Are you not signed up to the main Tiger forum?
There are usually a few sets of 3- point belts that get passed from one member to another for SVA purposes.
They (ahem) seem to fall off soon after though!
Andy.
soggy 3
posted on 3/3/07 at 09:45 PM Reply With Quote
Now you mention it i have seen them talking about belts on the toc forum.
Will have a word when i need them.
car builder
posted on 11/3/07 at 08:34 PM Reply With Quote
my avon passed with 4 point harnesses
and quick release buckle. the only thing i did was to make a very thin seat base as they measure up from the seat base.
Lightning
posted on 11/3/07 at 09:33 PM Reply With Quote
Mine failed as the rear mountings were approx 12mm too low. I borrowed 3 point belts to pass then put back on the 4 pointers. Having said that with the bottom squab out of the seat it probably would have been OK. I later changed the seats to GRP from Triton and these were low enough to effectivly raise the rear mount to the 450mm (don't quote me as thats from memory)
les
posted on 13/3/07 at 08:59 PM Reply With Quote
that last post is v interesting,
I have two tillet grp seats and 4 points that I was intending to fit after sva, but might try it for the test now-
has anyone passed this way?
quick other question, i was going to buy the 3" wide belts but the harness holes look very close together, any thoughts?
les
Cornholio351239
posted on 2/4/07 at 05:30 PM Reply With Quote
Where does the 3 point harness attach at the top? I have just bought a part built Avon and it has 4 point harnesses which are mounted too low at the top.
Rudy
posted on 2/4/07 at 07:02 PM Reply With Quote
If you have a genuine tiger avon roll bar than top attach to the roll bar (there is the holes).
Cornholio351239
posted on 2/4/07 at 08:52 PM Reply With Quote
I read on one of the forums that there have been issues where the roll-bar is bolted to the box frame and caused SVA failures as the bolts could crush the box section. Is this correct? What are the options?
andrew.carwithen
posted on 2/4/07 at 10:18 PM Reply With Quote
You could weld crush tubes into the box section.
Mine is an early chassis and my rear shock top mounting brackets are higher up than later versions and sit right under the box section. Therefore there is no room to fit the nut for two of the mounting bolts per side, if they were to protrude through the box section.
To overcome this, I have fitted the nuts inside the box section on these particular bolts, so that the rollbar is clamped to the top face only. (i'm hoping that by leaving the end plugs off, the SVA inspector will be able to see the nuts inside.)
