<<  3    4    5    6    7    8    9  >>
Author: Subject: Please post your dashboard layout pic
stevegough
posted on 3/9/10 at 04:37 PM Reply With Quote
and inside the glovebox
( not yet covered / painted )
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
View User's Profile E-Mail User View All Posts By User U2U Member   stevegough 's Aim
adithorp
posted on 3/9/10 at 06:08 PM Reply With Quote
Is the bottom edge padded? If not it has to be 19mm radius and the angles on yours don't look like that from the pictures.
Nice though.
adrian
http://jpsc.org.uk/forum/
stevegough
posted on 3/9/10 at 08:19 PM Reply With Quote
good point, Adrian - the bottom of the dash (left side only) has a 40mm diam section of waste pipe tubing filled with a shaped 2x2 piece of wood (to give purchase to the 7off 1 1/4" screws) - the ply is then shaped to it, and it is all covered with vinyl.
As the section over the driver is steeply angled and filled with steering column, it wasn't necessary / possible to do it on that side. (I hope).
There are more photos of the components in my archive under 'interior' but, as yet, none showing how I fitted the radiusing bit.
[Edited on 3/9/10 by stevegough]
Luego Locost C20XE.
stevegough
posted on 6/9/10 at 04:59 PM Reply With Quote
for Adrian - took a pic showing the bottom radiusing....
Luego Locost C20XE.
wescottishmatt
posted on 9/11/10 at 11:27 AM Reply With Quote
westy turbo
posted on 9/11/10 at 02:43 PM Reply With Quote
cat
posted on 4/1/11 at 01:03 PM Reply With Quote
http://www.flickr.com/photos/34192371@N00/5323163447/
[Edited on 4/1/11 by cat]
shaft
posted on 25/1/11 at 07:39 PM Reply With Quote
my opinion might be wrong you know...
My Zero Build Pics
westy turbo
posted on 6/4/11 at 01:28 PM Reply With Quote
previus lost...
Johneturbo
posted on 6/4/11 at 03:46 PM Reply With Quote
Here's mine
using the ZZR14 clocks, just a basic layout really have oil pressure gauge, i'm trying to use the bike clocks fuel gauge
not sure if it give a true reading yet.
i'll know when i run out of fuel
not a great piccy taken with my phone and low light
Dash layout
Dash layout
[Edited on 6/4/11 by Johneturbo]
hellberg
posted on 10/5/11 at 09:32 PM Reply With Quote
sdh2903
posted on 22/6/11 at 09:49 AM Reply With Quote
40inches
posted on 22/6/11 at 01:30 PM Reply With Quote
Yay! Finished ( I think!)
Wheel fitted
Wheel fitted
Reverse panel
Reverse panel
jabbahutt
posted on 22/6/11 at 01:51 PM Reply With Quote
The above has turned out superbly!! I take my hat off to you for a truly stunning job.
sssline
posted on 22/6/11 at 03:14 PM Reply With Quote
3rd attempt since owning the car -
[Edited on 22/6/11 by sssline]
https://www.facebook.com/groups/swkitcars/
jossey
posted on 22/6/11 at 03:22 PM Reply With Quote
New dash Hand made
New dash Hand made
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
stevegough
posted on 22/6/11 at 06:16 PM Reply With Quote
Originally posted by jossey
New dash Hand made
New dash Hand made
What happened, Jossey? - looks like a melt-down!
Luego Locost C20XE.
jossey
posted on 23/6/11 at 10:38 AM Reply With Quote
It looks better on the car than sat on the back of my Tintop with clouds above it.
Gonna fit it with the Cowling to hide the Steering hole.
New dash Hand made
New dash Hand made
David Johnson
myke pocock
posted on 19/8/11 at 09:52 PM Reply With Quote
Mk 2 Escort instrument pod with the front curved face cut off flat, a piece of clear acrylic glue on and then a piece of thin alloy cut, shaped, bead blasted and glued to the front.
RK
posted on 31/8/11 at 02:42 AM Reply With Quote
Very nice. Where did you get the rubber trim around the top? Mine always end up looking like a 5 year old did them. I've done 4 of them. Seriously.
[Edited on 31/8/11 by RK]
i_froloshki
posted on 5/1/12 at 06:32 AM Reply With Quote
Originally posted by Jasper
Hi there Jasper,
I would like to ask you if the alcantara fabric that you have used is with some amount of foam on its back, or just the fabric itself? And the other question is - how do you treat the curves on the dash - heat, steam or just stretch it? I just drilled my dash yesterday and it is ready to be covered, but i do not know what fabric to put - with or without foam. Any advice will be highly appreciated.
Regards
Yavor
Angel Acevedo
posted on 5/1/12 at 03:37 PM Reply With Quote
Hi there Jasper,
Regards
Yavor
Yavor,
Foam has the advantage that looks better around corners, IMO, but has a couple of drawbacks, it gets cooked over time which may lead to the separation of the top layer and on open cars it retains moisture.
HTH.
AA
Talkiet
posted on 7/1/12 at 11:27 AM Reply With Quote
My Dash from New Zealand
I can't take credit for this since I bought the car off the original builder, but I really liked the dash layout. (I have added the AF gauge and mounted a remote set of Megasquirt ECU LEDs though)
Not being in the UK, we don't have a lot of the SVA radiusing issues you have.
I've taken a lot of inspiration from these forums and have a bunch of ideas welling up... Unfortunately a substantial number of them depend on me learning to lay up Carbon Fibre first :-)
Cheers - N
steve m
posted on 7/1/12 at 11:54 AM Reply With Quote
bobinspain
posted on 7/1/12 at 03:33 PM Reply With Quote
Wanted 'gated' aircraft switches, having seen them on another factory-built car, complemented by 'Savage switches' in the centre all set in a c/f factory dash.
[Edited on 7/1/12 by bobinspain]
<<  3    4    5    6    7    8    9  >>
