westindy
posted on 11/4/07 at 07:22 PM |
zx9r engine pickup problem?
My 98 zx9r indy is not running right it will rev standing no problem but will struggle under load to pull beyond 7k, it was running ok. I've
changed the fuel pump, plugs, ecu but no joy any ideas? It almost feels like a fuel starvation problem!
Help!!!
Rgds, Paul
jacko
posted on 11/4/07 at 07:35 PM |
Hi i don,t know about bike engines but is it blocked fuel filter , is it like it is on choke ? [ is it on carbs or fi ]
westindy
posted on 11/4/07 at 07:46 PM |
zx9r problem!!!!!!!!!!
Its carb version and filter was replaced when I tried a different fuel pump!.
asn163
posted on 11/4/07 at 08:11 PM |
Have you tried another voltage regulator/rectifier?
We had similar probs. with our blade engine. I thought it was a fuelling problem but it turned out to be the regulator.
One quick check is to see what voltage you are getting across the battery with the engine running and see if this is higher than the spec. max. If it
is then the regulator is faulty.
Simon
russbost
posted on 11/4/07 at 09:39 PM |
If you haven't got the airbox sealed to the carbs or have changed the airbox in any way or have air leaking into it will make it run like a bag
of sh*t, very very weak, no pickup on throttle
G.Man
posted on 12/4/07 at 03:50 AM |
have u checked mixture? what about HT leads?
Opinions are like backsides..
westindy
posted on 13/4/07 at 05:31 PM |
rectifier/regulator
Tried a new rectifier/regulator today with no change, driving me mad!!
Best try HT coils then carbs? what do you reckon?
Minicooper
posted on 12/6/07 at 02:55 PM |
Strange it was okay, but does sound like mixture I would get it on the rolling road to see whats happening, even minor changes to the air filter can
dramatically change how it runs, for instance my mate changed his R1 TTS filter to a conventional air filter from the bike in order to make it
quieter, ran very poorly, but it did make it quieter
Minicooper
posted on 12/6/07 at 03:11 PM |
Whoops two months late, nevermind
