Author: Subject: Edis Sheilded wireing
ibakes
posted on 2/5/07 at 10:56 AM Reply With Quote
Morning all
Just putting together the wiring loom for me Megasquirt running the Edis system and most things I have read tell me to shield the crank sensor and cables to the coil pack as here
But the original cable for the Edis wiring (cos I got the loom included) are not shielded. should I re-do the wires with a shield or leave it as ford created it?
Ta
Agriv8
posted on 2/5/07 at 11:12 AM Reply With Quote
personally I will sheild it.
Ford had the advantage of a nice large engine bay so the could route it away from any causes of interferance. Man hours to test watch and monitor ect.
where as kit car looms we dont have easy access to osiloscopes ect that can see if it is picking up interferance.
if it is sheilded it can very likley crossed of the possible problems list if you run into prolems further down the line.
regards agriv8
ibakes
posted on 2/5/07 at 11:55 AM Reply With Quote
Ok thanks for that, next problem is, Anyone know where i can get 2 core shielded cable off the roll??
Ta
turbodisplay
posted on 2/5/07 at 12:14 PM Reply With Quote
Maplin.
Best bet, if not using shielded wires is to twist the wires together, almost as effective due to noise being picked up the same polarity, so canceling (only vr sensor, PIP and Saw will suffer.
Darren
Schrodinger
posted on 2/5/07 at 04:52 PM Reply With Quote
How much do you need?
I have about 1.8m in my garage
Ta
chriscook
posted on 2/5/07 at 05:22 PM Reply With Quote
Microphone cable from Maplin..
owelly
posted on 2/5/07 at 05:27 PM Reply With Quote
And never ground both ends of the cable!
http://www.ppcmag.co.uk
ibakes
posted on 2/5/07 at 06:27 PM Reply With Quote
Good Call
Just about to do that, I have the PIP and Saw signals with only about an inch unshielded wither end, getting some more cable off a friend hopefully
am i right in thinking that the Tachometer gets it signal from the PIP signal??
posted on 2/5/07 at 06:35 PM Reply With Quote
This place sells proper automotive screened twin cable (tough material, etc.). Not expensive either.
Also has all sorts of EDIS bits & pieces, trigger wheels, etc.
HTH
Micael
posted on 2/5/07 at 09:11 PM Reply With Quote
They seem to have some good stuff.
But who are they and where??
I can't find any info about the company. No physical address, phone, VAT-reg, etc
Does anyone know who they are?
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
posted on 2/5/07 at 09:16 PM Reply With Quote
Trigger Wheels?
I'm not sure who or where they are - but I think the bloke who runs it is (or has been) a member of this forum.
I've bought a trigger wheel and cable from him - no complaints.
martyn_16v
posted on 2/5/07 at 09:45 PM Reply With Quote
Pin 11 on the edis module provides a tach output (CTO), but it's a 12v square wave which some tachometers won't trigger from (most are designed to trigger from the much higher voltage spikes at the coil). If you have a search on t'internet there's quite a bit of info on getting tachs to work on wasted spark systems though, that's if yours won't work from the CTO.
cng1
posted on 4/5/07 at 07:31 AM Reply With Quote
That would be us
Micael
posted on 5/5/07 at 01:21 PM Reply With Quote
Then i suggest that you guys put your address and phone numbers on your website. As a serios company
Micael Moose Åman
