Arthur T
posted on 16/5/07 at 08:52 PM |
v8....glad this is easy to work out!..........NOT!
after MANY MANY hours trying to get the right clutch i have found that the company have not supplyed and bolts or washers!
i have a 3.9L rover V8 and a T5 box and now a New clutch!!! but i can not put it together with out the bolts .. does any one know where i can get them
from at a good price?
Mant thanks
Arthur
Agriv8
posted on 16/5/07 at 09:03 PM |
Arther.
Assume you need presure plate to flywheel bolts ??
regards
Agriv8
chrisj
posted on 16/5/07 at 09:06 PM |
I found this chap who had spent a lot of time on an seight. He has a couple of good links on his website to a couple of good rover builders.
www.seight.com![](/images//smilies/cool.gif)
Bob C
posted on 16/5/07 at 09:07 PM |
Aren't these just 5/16 UNCs?
Bob
PS - make allowance for failing memory......
[Edited on 16/5/07 by Bob C]
craig1410
posted on 16/5/07 at 09:28 PM |
Can't you get them from Rimmer Bros?
wilkingj
posted on 16/5/07 at 10:16 PM |
Any Land Rover Dealer. You just to need to know which flywheel you have. There are two sizes 9" (might be 9.5" and 10" plates.
(could be 10.5"
The larger clutch cover wont fit in a LT77 bellhousing.
Dont know what bell housing you have, Try www.Paddockspares.com - Give them a ring. or famousfour.co.uk, or www.johncraddockltd.co.uk just google for
it. ring thm up and ask for the bolts.
Its not that hard. Just tell them its for a V8, and the size of the clutch. or take the flywheel to a local nut and bolt dealer.
I suspect UNC is probably correct, as its a Buick 215 engine in essence, ie its American design.
Best Regards
Geoff
http://www.v8viento.co.uk
DanP
posted on 18/5/07 at 06:47 AM |
V8tuner.co.uk does clutch bolts at reasonable price - only a few quid.
HTH
Dan
[Edited on 18/5/07 by DanP]
