twybrow
posted on 18/5/07 at 09:09 AM |
Laying Floor
I am planning on laying floor tiles in our kitchen. We took up a load of vinyl tiles which were stuck down with what look slike bitumen. The chap who
fitted our kitchen said it was a great surface to tile onto, but the chap in the tile shop said it really isnt! Anybody got any experience with this?
Do i need to spend several weeks scraping the bitumen off the floor?
flak monkey
posted on 18/5/07 at 09:14 AM |
I cant remember for the life of me what that stuffs called, something proof i think. Its basically a bitumen adhesive, comes in tins and you just
brush it on.
Stuck the tiles down in our kitchen with it. Does just the job. Horribly messy and sticky though.
Sera
http://www.motosera.com
twybrow
posted on 18/5/07 at 09:19 AM |
That is what we have on the floor and we want to put normal ceramic tiles/adhesive over the top... It is a question as to whether the new adhesive
will stick!?
flak monkey
posted on 18/5/07 at 09:28 AM |
I remembered, its called Synthaprufe. Knew it would come to me eventually.
It *should* be compatable with most building materials and adhesives as its designed to be used as a liquid damp proof as well as an adhesive for
vinyl tiles.
A builder will be along in a minute to put me right no doubt.
Sera
jobsagooden
posted on 18/5/07 at 09:30 AM |
As long as the bitumen stuf isn't too (i.e. much higher in some areas than in others) you should be fine as your Ceramic floor tile adhesive is
quite thick and should level well.
However technically speaking you should scrape all the cr*p off first.
twybrow
posted on 18/5/07 at 09:33 AM |
It is lovely and flat (not like our walls!) I think we will try laying one and see how easily it rips back up. It's not like they move once
down, they should stay very firmly in position... We shall see!
millemg
posted on 18/5/07 at 10:02 AM |
I just "de-tiled" the floor in our kitchen. It has the black ashphalt floor like yours, and the ceramic tiles were layed straight on it
with normal tile adhesive.
They were stuck like fcuk !!!! Needed a good chiselling to get them up. !!!!!
twybrow
posted on 18/5/07 at 10:07 AM |
Well that sounds enouraging! I really don't like the thought of having to get it all up!
andyharding
posted on 18/5/07 at 10:13 AM |
I'm not sure on "proper" take on this but my parents tiled their kitchen floor onto the same stuff and they're still stuck
10yrs later.
BKLOCO
posted on 18/5/07 at 11:31 AM |
Floor tile adhesive is a cement based product and will stick your floor tiles to Synthaprufe with no problems as long as you use a "full
bed" of adhesive and don't be a tightwad by spot bonding the tiles. Which as a point of interest should never be done on either floor or
walls..
dilley
posted on 18/5/07 at 02:19 PM |
there are loads of different adheisives available,bal do a good range although expensive its the best on the market,don't skimp on adheisive!!!
it may be worth laytexing the floor to get it nice and smooth,this will make tileing an easier job if your not used to it.
posted on 18/5/07 at 06:43 PM |
is it wood or concrete floor? If concrete, rock on, if wood consider screwing some 8mm ply down first, makes it more level and solves the goo problem.
Use flexible adhesive if tiling onto wood.![](/images//smilies/smile.gif)
locogeoff
posted on 19/5/07 at 01:24 AM |
Remember floors are like women
Lay then properly once and you can walk all over them for years
I'll get me coat!
twybrow
posted on 21/5/07 at 12:05 PM |
Guys, thanks for some very useful information. The kitchen is all a concrete floor. The bathroom will have to be done onto a decent piece of ext grade
plywood. I think the concensus is that it is possible. I think the acid test will be stick one down and see how it goes (lets just hope I can remove
it again). Many thanks - such a wide knowledge base!
