Author: Subject: Welds
speedyxjs
posted on 9/6/07 at 08:01 PM Reply With Quote
Welds
Iv been out practicing my welding ready to finally start my build tomorrow
Only thing is i remember reading somewhere about the need to tidy your welds for SVA. Is this true? If so, what is the best way to do it without weakening the weld?
thunderace
posted on 9/6/07 at 08:54 PM Reply With Quote
i know a guy who done it to a new r1 as he was gold plating the frame for a show and most of the bike buying that diy gold plating kit thats on ebay.
the frame cracked the first time he used it on the road at the front yoke, so i would dress it to remove any sharp bits but thats it . or it will fall apart for sure.
Minicooper
posted on 9/6/07 at 09:23 PM Reply With Quote
Once your happy with your welding, you should really only be dressing back the odd blob of weld/spatter here and there. As you said, knock the obvious bits off, sharp edges, etc and leave it, if your having problems getting neat strong welds first time, more practice would be better than grinding loads of welds out
rjbrookes
posted on 9/6/07 at 09:36 PM Reply With Quote
and make sure it dont fail at a later date!
nitram38
posted on 9/6/07 at 09:37 PM Reply With Quote
Buy yourself some anti-splatter spray before you start. Any small balls of weld will come off if you knock them off using the edge of a file at 90 degrees.
Make sure that you have enough gas and that you weld were there is no draught. That way you should have very little to clean up.
ed_crouch
posted on 9/6/07 at 09:59 PM Reply With Quote
Once the machine is set up, you should have no problems.
Went on a welding course a couple of years back: even the pros have a short practise before beginning the job.
Also, if youre having a high current intense welding session, give the poor machine a break, as when run flatout, the transformers get fecking hot: their resistance goes up, and your weld current goes DOWN!!
Result: poor metal penetration and weak welds. You'll notice it, cos the quality of your welds will deteriorate. Go indoors for a pie and a beer for 10 minutes!
DIY machines do have a stated duty cycle, and its worth bearing in mind.
Also, avoid using an extension lead if you dont have to: a nice coil of wire gets a bit warm too...
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
gazza285
posted on 10/6/07 at 12:22 AM Reply With Quote
only shite welds need dressing.
speedyxjs
posted on 10/6/07 at 07:47 AM Reply With Quote
Thanks guys. I hardly had any spatter while i was practicing so i should be ok.
What about the parts where the body pannels averlap the chassis. Should they be filed down?
jollygreengiant
posted on 10/6/07 at 10:12 AM Reply With Quote
My ONLY advice is :-
Try NOT to join the TWG (Trafalgar Welding Group ....... cooo coooo cooo coooo)
Confused but excited.
posted on 10/6/07 at 12:09 PM Reply With Quote
Do what Boyd Coddington does and slap a load of body filler over them!
