ayoungman
posted on 11/6/07 at 12:24 PM |
toyota rav4 door card removal
Anyone know how to remove a door card on a 52 rav4 glx ? I can only see one screw fixing. I don't want to start levering it off if there are any
more fixings hidden.
"just like that !"
COREdevelopments
posted on 11/6/07 at 06:01 PM |
hi, i can tell you. im trying hard to picture it in mind
on the door you have big handle to close the door. Right? on that handle is an insert bit of grey pastic, this can be prised of carefully, there
should be a little grove there. behind that should be 2 big screws,
you also have to take the open lever surround off. then you can prise the card off, i would use a flathead srew driver and insert it at the bottom of
the door, then it should come off, dont forget those crappy plastic clip screws on the front of the door card. hope this helps, if you need anymore
help let me know as i work in a toyota dealership.
rob
[Edited on 11/6/07 by COREdevelopments]
ayoungman
posted on 11/6/07 at 09:17 PM |
many thanks, i'll av a go on Wednesday. cheers from alan
"just like that !"
ayoungman
posted on 13/6/07 at 04:20 PM |
Job done. Thanks. Window channel had become undone ! Glass hell to the bottom !. Bit of a problem really. Now sorted though. Unusual issue with
Toyotas, normally bullet proof
"just like that !"
