Author: Subject: Sierra Top Column Bush
PeterW
posted on 13/6/07 at 11:05 PM Reply With Quote
I want to remove all the alloy crap at the top of my steering column and just leave a plain tube with a single new stalk for the indicators.
However, the alloy bit holds the top bearing for the inner column and I'm damned if I can work out a decent way to put a bearing back into the top so the column doesn't wobble.
So 2 questions...
Anyone done it before...?
How did you do it...?
I don't want to reinvent the wheel for the sake of picking someones brains if possible !
Also, if I pull hard on the column the bottom bearing pulls out of its tube (Tiger Cat E1). How can I stop that..? Jubilee clip below the mounting..?
Pete
bigrich
posted on 13/6/07 at 11:15 PM Reply With Quote
you can use a jubilee clip to secue the lower bush and this is my column top i just use a on/off/on toggle switch on the dasy for the indicators
Rich
PeterW
posted on 14/6/07 at 08:06 AM Reply With Quote
Rich
That looks like you have turned down the top alloy steering lock assembly..? IS that the case..?
I was looking to replace it entirely - not sure whether I could use a Delrin rod or somthing similar to make a bearing to fit.
Pete
ayoungman
posted on 14/6/07 at 10:50 AM Reply With Quote
Can you get a large spherical joint(rose joint) to replace the complete bearing. That would allow you to secure the top of the column properly. HTH
"just like that !"
PeterW
posted on 14/6/07 at 04:15 PM Reply With Quote
Thought about a bearing, but the size of the tubes involved (19/20mm bore, 36mm outer) means there are very few bearings that meet those requirements.
I was thinking the sort of forces a steering wheel gets, a long delrin or similar bearing may work better. Anyone able to turn something down like that for beer tokens..?
Looks like I need to keep thinking...
Pete
