Author: Subject: new windscreen assembly
marc n
posted on 14/6/07 at 12:36 PM Reply With Quote
hi all
we have finally completed our windscreen assembly
kit consists of :-
1 x kitemarked glass bonded into a black powdercoated alloy frame
2 x black powdercoated side supports
1 x black grp finishing strip
1 x fixing kit
best regards
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 14/6/07 at 12:37 PM Reply With Quote
chockymonster
posted on 14/6/07 at 12:52 PM Reply With Quote
Do you have a side on view Marc?
neilj37
I am I right in assuming that it is okay to fit this after SVA approval as is or would I need to add windscreen wipers & a demister as well??
Agriv8
posted on 14/6/07 at 12:57 PM Reply With Quote
After SVA is easier - definatly -
Regards
Agriv8
worX
posted on 14/6/07 at 01:00 PM Reply With Quote
easier post SVA for sure, but why don't you just fit it for SVA and fit it correctly?
marc n
posted on 14/6/07 at 01:36 PM Reply With Quote
for sva you will need wipers and demister, if you have ever driven a car before that is missing either or in some cases both you would definately put both on for safety so before or after sva it doesnt matter, as for safety you will need both
best regards
marc
marc n
posted on 14/6/07 at 01:42 PM Reply With Quote
mstepien
posted on 14/6/07 at 03:04 PM Reply With Quote
It looks way better than the first one that you've shown some time ago, the one with thick frame and with the glass with flat lower edge (if you know what I mean). I think I'm tempted to install it, especially since it always rains here (in Belgium), maybe as an easy-to-remove option ?
Regards,
Michal
DarrenW
posted on 15/6/07 at 10:14 AM Reply With Quote
I bet that was easy to design..... NOT!
Just a thought - one advantage i see of having a screen is being able to fit wet weather gear at some point. Would such wet weather gear just need a bit of channelling adding to the top of the screen frame or would it be an idea to add this in now?
Ive never looked closely at hoods but it would be horrible for someone to try and add poppers ata later date and crack the screen. Probs easier to add to the frame before the screen is bonded in.
Just a thought - delete / ignore as necessary
G.Man
posted on 26/9/07 at 06:25 AM Reply With Quote
Looking good Marc
Opinions are like backsides..
