Author: Subject: zetec 130 bhp
mr T
posted on 16/6/07 at 09:32 PM Reply With Quote
zetec 130 bhp
is 130 bhp at wheels about right for a 2lt zetec its got honda blackbird carbs newman fast road cams no cat.
oadamo
posted on 16/6/07 at 09:42 PM Reply With Quote
the engines are
136 BHP 93-96
130 BHP 96+
but i found a 2L in the scrapyard with 139ps on the cover so now i have the head off that. so your already got 130.i dont no what you will have with the carbs and cams and no cat but you gotta have about 150
adam
[Edited on 16/6/07 by oadamo]
posted on 16/6/07 at 09:43 PM Reply With Quote
arent manufacturer figures always flywheel bhp?
oadamo
posted on 16/6/07 at 09:44 PM Reply With Quote
bugger i hope not lol
adam
mr T
posted on 16/6/07 at 09:55 PM Reply With Quote
i think this engine has 100 bhp at wheels in a mondao
big_wasa
posted on 16/6/07 at 09:57 PM Reply With Quote
yep quoted at crank.
2l with carbs and good ignition should give 165 @ crank, add the cam and it should be 175 ? shouldnt it ?
Take away transmision losses ect and I would still hope for a tad more than 130 @ the wheels.
I am hoping for at least that with out the cam.
I think it depends on the dyno you use ?
mr T
posted on 16/6/07 at 10:04 PM Reply With Quote
running omex ecu disapointed with 130 bhp at wheels +25% transmision would give 175 bhp at fly 175
- 25%
= 130
its not enough
oadamo
posted on 16/6/07 at 10:09 PM Reply With Quote
- 25%
= 130
its not enough
********turbo**********
adam
mr T
posted on 16/6/07 at 10:11 PM Reply With Quote
in my hands that would be deadly i'm bad enough in a scooby
big_wasa
posted on 16/6/07 at 10:28 PM Reply With Quote
So how does it compare with a scoobie ?
I havnt driven either
mr T
posted on 16/6/07 at 10:33 PM Reply With Quote
feels a bit faster to 60 than the scooby no competition in wet
bimbleuk
posted on 17/6/07 at 01:59 AM Reply With Quote
Just what I've observed but a typical 2L Zetec on the rollers I use will show 150-160BHP flywheel with carbs or throttle bodies, no internal mods.
A good method for working back from flywheel figures is to subtract 10 BHP and then take 10% off for FWD or 12% for RWD. More simple allow about 17% for loses. Thats been a good method on loads of cars I've seen over the years.
posted on 17/6/07 at 12:24 PM Reply With Quote
- 25%
= 130
its not enough
175 is pretty good from a zetec with standard head and cam.
StevieB
posted on 17/6/07 at 01:27 PM Reply With Quote
- 25%
= 130
its not enough
But if the BHP at wheels is known, and using Bimble's calcs of 17% loss, that would put about 156 at the flywheel, which is probably a bit more likely.
mr T
posted on 17/6/07 at 02:36 PM Reply With Quote
156 bhp is 20 more than standard . carbs could give 10 bhp. cams 10 -12 bhp.omex ecu and no cat 10 bhp . thats 30-32bhp that would give 166 -168 bhp at fly -17%=139bhp where has my 9bhp gone??????????
roadboy
posted on 19/6/07 at 02:57 PM Reply With Quote
Mine has 208 bhp & 172 ft/lbs on throttle bodies, Emerald ecu, uprated cams & some head work but standard valve sizes.
Figures on Emerald rolling road.
Ian
Jude Performance Services
