Indymike
posted on 19/6/07 at 06:33 PM |
Joining brake lines
Is it acceptable to join two pieces of copper brake line by screwing a male and female end together? I need to reroute a brake line which will then
end short and don't want to take all the riveted p-clips off!!
Build manual? What build manual?
fesycresy
posted on 19/6/07 at 06:40 PM |
I had a dodgy T piece, thought it was the flare and had to cut a piece in.
I bought a shunt (think thats what its called) from MAC#1.
Passed SVA and more importantly doesn't leak !
posted on 19/6/07 at 06:51 PM |
You need a one stage flare on one pipe and a two stage flare on the second. Peugeot use this system on the 205 models . Personally I prefer to use a
proper joiner
matt_claydon
posted on 19/6/07 at 06:52 PM |
Yes, that fine as long as the ends are appropriately flared. What's not fine is joining pipes by brazing etc, even if you sleeve.
posted on 19/6/07 at 07:05 PM |
Proper joints are not much money from Namrick or local spares shops £2 to
do the job properly
Mark Allanson
posted on 19/6/07 at 07:41 PM |
Sorry, its an mot fail, I haven't the faintest clue why, but they insist on a proper joiner and 2 mail unions
Mark Allanson
posted on 19/6/07 at 07:44 PM |
Just phones a mate in VOSA, its the copper to copper joint that isn't acceptable - and he doesn't know why!!
posted on 20/6/07 at 07:00 AM |
VWP also sell the joiners.
posted on 20/6/07 at 05:14 PM |
Perhpas the extra thickness of two copper flares pressed together is more prone to creeping over time and loosening the joint?
Didn't know it was an MOT fail though, useful info.
