Author: Subject: Slippy pedels
dhollin3
posted on 21/6/07 at 12:21 PM Reply With Quote
Slippy pedels
A couple of SVA questions:
My SVA picked up on me not having non-slip padels. What is the best way or getting them to pass?
Also the mudguards are fouling on the tyres. Is it going to be ok to lift them a bit higher as it is the flanges that tough the tyre. I.e. The width of the mudguards are slightly too small but this wasn't picked up as being a problem.
posted on 21/6/07 at 12:25 PM Reply With Quote
For the pedals you can get some wet and dry and either some spray mount or some double sided sticky tape and stick sections of the wet and dry on.
Or... if you know any people interested in skate-boards you can get deck tape which you put on the top surface of the board for good grip... (it's courser and already sticky on one side).
[Edited on 21/6/07 by BenB]
Humbug
For the pedals, do a search, but from memory the typical methods are:
Stick sandpaper on
Stick skateboard grip tape on
I stuck a bit of Woolworth's rubber shoe sole
Re mudgaurds - I don't think thre is a minimum height requirement (= distance from tyre) so just move it far enough away not to foul. You say they are not wide enough, but the rule is that it has to cover the wheel, so if the tyre sticks out slightly further you should be OK
tks
mhhh me is told you need rubber on the pedals... not anti slip..
Tks
Humbug
posted on 21/6/07 at 12:26 PM Reply With Quote
2 Stewies posted at the same time!
JAG
posted on 21/6/07 at 12:31 PM Reply With Quote
I can confirm that skateboard deck tape WILL pass SVA - mine did. It also provides a great non-slip surface
Justin
tks
posted on 21/6/07 at 12:32 PM Reply With Quote
3!!
posted on 21/6/07 at 12:34 PM Reply With Quote
Guess the uber shiny ST pedals caused problems for both of us!
ps Deck tape worked for me at SVA #2
nitram38
My new wilwood pedals come with the sand paper grip as standard.
dhollin3
posted on 21/6/07 at 12:47 PM Reply With Quote
Thanks for all your help. I am just plugging though the defect notes now!
tks
posted on 21/6/07 at 12:50 PM Reply With Quote
can we post the places where we passed SVA with a certain part on it.
makes life easyer for us all
Tks
Ian D
posted on 21/6/07 at 01:03 PM Reply With Quote
That post is a good idea. It will highlight their inconsistencies. Reading other posts a DVLA section should proivide great reading. Should that be an incompetence section?
rjbrookes
posted on 21/6/07 at 03:38 PM Reply With Quote
i cut a square out of my Volvo rubber car mat!
RazMan
posted on 21/6/07 at 05:50 PM Reply With Quote
You can kill two birds with one stone - get a cheap set of blingy pedal covers from eBay (about a tenner) and bolt them to your pedals.
Nice and grippy and they look good too
Raz
flak monkey
posted on 21/6/07 at 06:22 PM Reply With Quote
You only need non slip on the brake pedal AFAIK.
Sera
http://www.motosera.com
bob
posted on 21/6/07 at 06:33 PM Reply With Quote
I used a couple of the ali bolt on type as Razman mentioned. Rescued attachment MK Indy build pics 120.jpg
caber
posted on 21/6/07 at 07:53 PM Reply With Quote
IKEA sell non slip tape in the Patrull range about £3 for miles of it!
caber
