Author: Subject: avon wishbone dim problem
Evrim
posted on 2/8/07 at 06:50 AM Reply With Quote
I am making the wishbones and I realize that Mr. Jim's book (second edition)gives the dimensions of front bottom wishbone wrong as mentioned into attached fig. So which is the correct dimension between bushes?
The same problem found for rear top wishbone(on page 77 Drag 6.9b).When I calculate the space between rose joints holes by given data i found 60+32+100+32+80=304mm -25.4=278.6mm but he gives 280 mm
Evrim
[Edited on 2/8/07 by Evrim]
fazerruss
posted on 2/8/07 at 07:10 AM Reply With Quote
just make them to the specified outside dimensionns of the bushes then bolt on the u brackets before you tack them on to the chassis that way they are sure to fit.
My chassis is now complete no thanks to the book!
Rudy
posted on 2/8/07 at 07:47 PM Reply With Quote
I will measure within few days and let you know.
Sorry about my English
t.j.
posted on 3/8/07 at 08:41 PM Reply With Quote
I'm sorry, but you will find more and more.
Than someday you will throw the book in a corner.
definitly wrong:
Drg 6.6a wrong measurements
Drg 6.4 looks like the 90 degr is at toprail but has to be at the lower or you will have zero caster!! (it compensate the 5.30 degr!)
So I used it for the idea, but now there is less AVON and more and more my insperation found in the frame.
Rudy
posted on 4/8/07 at 07:00 AM Reply With Quote
Hey T.J. ,
I was looking at you (?) on your avatar, it is nice to put a face on the name.
t.j.
posted on 4/8/07 at 07:29 AM Reply With Quote
It is "Dirk"; was a figure in in TV-serie "van kooten en de Bie"
Dirk was the drunk
http://www.kootenbie.nl/
[Edited on 4/8/07 by t.j.]
Rudy
posted on 4/8/07 at 06:59 PM Reply With Quote
May I use your avatar in a italian forum ? It is too funny
t.j.
posted on 4/8/07 at 07:13 PM Reply With Quote
It's not mine, so you can use it freely!
Although a paid for holiday in Italia would be great
Btw: did you measured the wishbone for the bloke or what?
Greetings from sunny Netherlands
Rudy
posted on 5/8/07 at 11:07 AM Reply With Quote
I can't measure it perfectly becouse it is already fitted, but seems to be 334 mm. However if you are building it and brachet, I think you should follow T.J advice. And also, bracket did not "meet" wishbone perfectly, so again follow T.J. advice.
T.J. I can't pay you a holiday but if you will came near Venice I will be happy to pay a Pizza
t.j.
posted on 5/8/07 at 06:26 PM Reply With Quote
Hmmm like Pizza
Next year maybe. We're just back from southern France. (Montpellier)
So my wallet is very empty now
And also a wheel bearing on my Audi A4 which cost my 180 Euro! Why don't they just make simple bearings anymore?
Evrim
posted on 6/8/07 at 02:05 PM Reply With Quote
Thanks Rudy
