New Topic New Reply
Author: Subject: thinking aloud - DIY v8 bike engine
posted on 23/8/07 at 03:48 PM Reply With Quote
Here is the idea - is it DIY dioable?
1. Take two 4 cylinder bike angines, let's say 750 cc to get lower car tax.
2. remove the lower part of the casing and using metal plates, somehow stick them side by side.
3. get a couple of gears e.g. old car geabox and stick same size gear onto each shaft. One engine is rotating in other direction so the gears will turn right way.
4. attach another gear to one engine so that is truns another gear in ration 2:1 (gives car gearing.
5. fit a car fly wheel to the dear and mate to car gear box.
6. Make sump and sort out oil system.
So how feasible is this for a DIYer with a drill press, welder and hammers of verious sizes?
worX
posted on 23/8/07 at 03:51 PM Reply With Quote
It all depends on the Hammers of various sizes in my opinion!!!
novacaine
posted on 23/8/07 at 03:53 PM Reply With Quote
you make it sound so easy, i might have a go at making one this afternoon and ill test it tomorrow
flat would be easier but in either case would require custom crankshaft and possibly custom con rods, but after that i suppose your ok, i seem to remeber a story of a V8 hayabusa lurking somewhere in the depths of the internet
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
Neil P
posted on 23/8/07 at 03:54 PM Reply With Quote
It's a complex job, you'll probably need to invest in a file too!
posted on 23/8/07 at 04:04 PM Reply With Quote
this is rather interesting.
I bet he had a saw too
MikeR
posted on 23/8/07 at 04:12 PM Reply With Quote
you'll need gaffa tape, if you can't fix it with gaffa tape - you've not used enough.
with your idea you wouldn't need custom crank etcetera as they'd be side by side.
You'd probably be better using a plate thats shaped like /-\ with the engines mounted on the / and \. That way you will hopefully find the inlet / outlet easier / not fouling.
The other problem is making something for the crank to run in and then something for the 'final' drive to run in.
Would it not be easier to take two bike engines, solidly mount them together then instead of a two flywheels do what you suggested. Same idea, just perhaps a little less work.
posted on 23/8/07 at 04:17 PM Reply With Quote
^^^ - yep -that is the idea - each bike is running using its original crank but the cranks are extended to fit on gears that run in opposite directions.
The tricky bit is then getting the final drive, nothing a bit of sikalex can't fix.
pewe
posted on 23/8/07 at 04:19 PM Reply With Quote
Laverda tried a V6 in the late 70's/early 80's by strapping two 3 cyl. engines together.
Some pics on Youtube
Can't remember why but it never was that reliable.
Cheers, Pewe
arrybradbury
posted on 23/8/07 at 04:30 PM Reply With Quote
Something like this....
http://www.springsspeedway.com/default,837.sm
Looks like a good final year project, i wonder if they'd let me do something like that
matt_claydon
posted on 23/8/07 at 04:59 PM Reply With Quote
Would be easier if you mount them inline and make a straight-8, guess you'd have problems fitting it into a seven though.
Whilst slightly more bizarre that your idea, this engine has three separate crankshafts joined with gears:
http://en.wikipedia.org/wiki/Delta_engine
posted on 23/8/07 at 05:00 PM Reply With Quote
If the cranks are both still used it will be a very wide engine and if the cylinders are inclined so the inlets don't foul it will put the exhausts in the middle where you can't get at them. The gears that connect the cranks would be large as well unless you have a lot of small ones or use chains to connect them. Use two Honda V4 750 engines joined together then half the work is already done for you
wheezy
posted on 23/8/07 at 05:10 PM Reply With Quote
Radical have done something similar with there V8. Only they use a single crank case with 2 Hayabusa cylinder heads. The only thing you need to do is design and build your own crankcase
Radical SR8
ned
posted on 23/8/07 at 05:15 PM Reply With Quote
If you're running the two engines with their existing cranks and just putting on what is effectively a transfer box it sounds as if all you'd be doing a creating a twin engined car like tiger did years ago!!
Ned.
beware, I've got yellow skin
MikeR
posted on 23/8/07 at 05:52 PM Reply With Quote
just thought of something - if you run two engines side by side and transfer the motion to a middle third gear - isn't that gear going to be turning the 'wrong' way.
You're going to need to either source a honda gearbox / rear diff or use engines that run the 'wrong' way for a 'standard' gearbox.
mark chandler
posted on 23/8/07 at 06:26 PM Reply With Quote
Arial square 4's used two cranks I believe.
What you are proposing does dilute some of the bec'ness as the multiplate clutch and keeps weight close to the centre, also I,m not sure if you lose the clutch you may lose the balance of the crank.... as in it will self destruct.
Better idea which is proven is two complete bike engines and have two gearlevers.
If in line you can get away with a central shaft which both connect to, if opposing I suspose you could have a chain on one and cogs on the other.
Tools are not so much of an issue, more on what you are capable of.
I know cart racers that used to use say Yamaha cylinders and heads on honda blocks but these were always 2 stroke.
Regards Mark
Dangle_kt
posted on 23/8/07 at 06:40 PM Reply With Quote
two engines, a zip tie - DONE!
smart51
posted on 23/8/07 at 07:03 PM Reply With Quote
At the end of each crank on a bike engine is the primary reduction gear. The two cranks could mesh together using these, except that the exhaust from one would point at the inlet of the other. One of them would be at the wrong angle too, so oiling would be tricky. and leaks, and extending the crank for a car clutch might be difficult.
do 750s rev as high as 600s? I want an engine that sounds like an F1 V10. a 1.2 bike engined V8 would rev to 16,000 which is almost like an F1 engine.
posted on 23/8/07 at 07:15 PM Reply With Quote
Read up on the history of the 1966 H16 BRM engine guys --- if Tony Rudd couldn't make it work.
The other option of making the cylinder blocks share a crank dosen't work either 8 cylinder crankshafts are much bigger diameters than 4 cylinder cranks.
Same goes for the straight 8 option.
Where 4 and 8 (& 6) cylinder engines are built as families sharing common components the 8 cylinder is designed first.
The Lous Espirit V8 is the exception but but the Lotus 907 4 cylinder was based on a horrible rough running cast iron Vauxhall engine that was designed to be half a V8.
indykid
posted on 23/8/07 at 07:58 PM Reply With Quote
only if you use one of those really big ones like they use on planning notices
tom
posted on 23/8/07 at 08:35 PM Reply With Quote
id be tempted to use just one standard crank for both engines, and cut each rod to half thickness so you could get two into the space of one. Then 'just' strengthen it to prevent them breaking.
higgsti
posted on 23/8/07 at 09:12 PM Reply With Quote
http://www.motorcyclistonline.com/features/v12_custom_kawasaki_2300cc/photo_04.html
ironside
posted on 23/8/07 at 11:18 PM Reply With Quote
There were 2.0 and 2.4 litre RST-V8 engines which were based on two bike engines and a shared crank.
Not very Locost I know but it sounded cool - 15k rpm, 74kg, 40 valve, quad cam and 340bhp.
The websites appear to have vanished, they were at http://www.rst-v8.com/ and http://www.rst-v8.co.uk/ but there is an archive copy from 2005 available here:
http://web.archive.org/web/20050104082101/http://www.rst-v8.co.uk/
It did happen, they put one in a Caterham SV (I know someone who drove it) and maybe an Elise too - I don't know what happened though - I'm surprised the websites have gone.
Angel Acevedo
posted on 23/8/07 at 11:59 PM Reply With Quote
Deja Vue
Apparently all the topic was written today, but I clearly remember reading it before.....
akumabito
posted on 25/8/07 at 03:28 PM Reply With Quote
...would it be an option to make a hybrid engine of sorts? Using a car V8 block, and filling it with bike pistons and rods? (using the original crank) that way you could still have a high-reviing engine..
Mixing and matching parts would be a nightmare though..
Let's have a quick look...
Cheap(ish) V8 engines:
The RV8 = 88.90 x 71.12
BMW 3.0 = 84 x 67.6
BMW 4.0 = 89 x 80
Getting bike bits to match... Here's a list of some engine specs..
There are not many engines that have a bore in the 80's. At least not many listed on that list..
Let's see... a bore between 84 and 90...
Suzuki DRZ400
Buell Lightening
Buell Ulysses
Well, even though that list is far from complete, it doesn't ist many options anyways..
The Suk is right out, it's a single cilinder.. you'd need 8 of 'm...
The Buell's are better, but there aren't that many of those around.. besides, it's a useless V-twin.
Hmm... what else's out there (having a tediously slow connection doesn't help the search either!)
Honda Goldwing? Nope.. besides it not revving very high, it also got a measly 70s-something bore.
Ya know what.. I believe this is a bad idea.
You'd still have the problems of mating the rods to the car crank, fixing the compression ratio, and if you thought of using the RV8, you'd also need to figure out what to do with the ciylinder heads to flow enough air in...
Also; it would probably be fairly heavy, AND you'd lose the sequetial transmission.
*slams head against wall for even bringing up this idea*
New Topic New Reply
