jamestziros
posted on 10/9/07 at 08:37 AM |
Maxi Lower Ball Joint - Nylock
Hi all,
I should have asked last time round. does anyone know where i can get Half Nylocks for a Maxi lower ball joint.
I think it is an M12 x 1.00mm pitch. I have tried Trident.
James
jamesbond007ltk
posted on 10/9/07 at 09:30 AM |
out of interest, why do you need a HALF nylock?
posted on 10/9/07 at 09:40 AM |
do such things exist? I've not heard of it until now
jamestziros
posted on 10/9/07 at 09:51 AM |
I have lost one nut from the ball joint, so while I was there I thought I'd put half nuts on (so I have a few threads out the top) so the SVA
man has nothing to complain about.
James
posted on 10/9/07 at 10:20 AM |
It's a common problem for only a small amount of the thread to protrude through.
Usual answer is to get a normal nylock and lathe 2-3mm off the bottom. Should be enough to get 2 complete threads showing.
jamestziros
posted on 10/9/07 at 10:43 AM |
Yes that is the other option but I still need a nut to replace the one I lost...
will remeasure tonight - maybe its 1.25mm pitch
James
posted on 10/9/07 at 11:54 AM |
These guys seem to be able to supply most things:
http://www.ahc-camberley.co.uk/fasteners.htm
Do you think a half nut it up to the job though? These things do hold your wheels on after all!
What about wire-locking the nut in place to be doubly-sure.
Hope that helps,
James
- Muhammad Ali
jamestziros
posted on 10/9/07 at 12:43 PM |
thanks James
