Author: Subject: Air Filter advice
desyboy
posted on 11/9/07 at 05:14 PM Reply With Quote
Air Filter advice
Can anybody recomend a decent air filter for an 03 R1 if so would you have any pics, prices and details where i could get 1 from please? Cheers Des
[Edited on 11/9/07 by desyboy]
RobBrown
posted on 11/9/07 at 09:21 PM Reply With Quote
I have been looking for myself an air filter for my R1 carbs, through searches on here and Google and have found out the following:
TTS £81, will supply rubbers if need be for extra(link)
ITG £81 ish, from FlukeMotorsport (link) or other
Pipercross £80 from locostparts (link), not sure if those holes in the baseplate are pre-cut.
For me because my carbs ar being mounted to a Pinto, I could just turn the standard airbox upside down, but that would mean cutting around the holes and re fixing them the other way up.
Don't be tempted by socks as they sap power apparently.
This is all assuming you don't just want info on a filter to go in the standard airbox.Appologies if this is the case, although TTS, ITG and Pipercross do offer standard replacement filters, which I am sure would be adequate.
Hope that helps
Rob
JoaoCaldeira
posted on 11/9/07 at 10:04 PM Reply With Quote
Either foam if you got clearance issues or original, as you can duct cold air from the front.
You can look into my galley to see how I overcome the cold air issue (I'm running foam)
my gallery
Looking at maps for each solution, I can see that the maps of the original box usually have less fuel added...
Joao
