Author: Subject: A good day And a Bad Day
ditchlewis
posted on 22/9/07 at 08:12 PM Reply With Quote
Well it has been a good day and a bad day
Good day......
I eventually got the nissan micra alternator wired, the new fan belt on, the battery connected and the car fired up
no fire and the alternator works well
the new EDGE starter motor works a treat
did a colour tune and the car runs better than it did before, not perfect but better.
Now the bad day
the only thing the car failed it's SVA on last time was the Speedo. i moved the sender unit forward nearer the magnets and tightened the bolts up.
went up the road and the speedo was working
came back down the road and it stopped
i looked in the tunnel and the sender has snapped in two
the bracket is un marked the nuts were on both parts
i dont know if the prop caught it, but i dont see how it could,
or
if i over tightened the nuts and it just snapped
whats the most likley cause?
i've ordered another but at 40 quid i dont want to ruin another.
ditch
cerbera
posted on 22/9/07 at 08:32 PM Reply With Quote
I overtightened my sender when fitting and that snapped also, didn't take much. I was much more careful with the second and added spring washers so I didnt need to tighten too much and was happy that it wouldnt shake loose.
Vdub boy
posted on 22/9/07 at 08:50 PM Reply With Quote
Exactly the same happen to me as well.
Was well careful putting the second one on
Leigh
locoR1
posted on 22/9/07 at 08:59 PM Reply With Quote
Glad its not just me that broke it tightening it up!
Nearly six years and this is the first time I've told anybody Not that I was keeping it quite or anything
Dave.......................
Check out my CB500T Cafe Racer build diary
Avoneer
posted on 22/9/07 at 10:19 PM Reply With Quote
Where abouts have you mounted the sensor?
Mine was halfway down the prop on my Avon and I went through 2 before realising how much the prop moved in all directions.
Mount it at the back on the diff flange if possible.
Pat...
Deckman001
posted on 22/9/07 at 10:35 PM Reply With Quote
'''Mount it at the back on the diff flange if possible.'''
Pat...
I guess it depends on the type of rear axle being used, ie 'live' or sierra
Jason
Sorry if that sounded like a critisism, it wasn't intended that way,
I meant to say magnets good at the back on IRS set up but no good for live axle installs
Jason
[Edited on 22/9/07 by Deckman001]
RazMan
posted on 22/9/07 at 10:55 PM Reply With Quote
Put a drop of threadlock on the sensor threads to make sure they don't rattle loose - they snap quite easily ..... but you know that now
Raz
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/9/07 at 11:03 PM Reply With Quote
Pat...
This is what i was going to say, Mine kept getting knocked everytime i tried to test it. I decided to put it so it read the bolts off of the drive shaft, no movement there!!
bob
posted on 23/9/07 at 08:30 AM Reply With Quote
Magnets on the diff flange for me, sensor fitted to a small ladder bracket i stole from the side of the house. Rescued attachment MK Indy build pics 161.jpg
snapper
posted on 23/9/07 at 08:47 AM Reply With Quote
Mounted the magnets to the diff end prop flange and mounted the sensor on a bracket braced and bolted to the diff cradle. There is no movement relative to the sensor at this point and i can change diffs and just reprogram the speedo
I eat to survive
I drink to forget
ditchlewis
posted on 23/9/07 at 09:34 AM Reply With Quote
I was just thinking that location was important.
i have put it halfway along the propshaft near the hand brake, but i was in the bath thinking and it came to me that the diff is mounted solid and i should put the sensor back there.
many thanks lads
ditch
Avoneer
posted on 23/9/07 at 06:48 PM Reply With Quote
That's the same problem I had on the Avon.
I mounted it halfway along the prop and you'd be suprised how much the prop moves.
I broke my 1st sensor as I was putting my car on the trailer for SVA!
Get it moved to the back and you'll be fine.
Pat...
