Author: Subject: Sierra 2.0 DOHC
Sporty
posted on 23/9/07 at 08:17 AM Reply With Quote
Sierra 2.0 DOHC
Seen a gearbox for one of these advertised, will it def be a type 9 or is there a chance it will be another type of box.
Ian
bob
posted on 23/9/07 at 08:20 AM Reply With Quote
There is a good chance the DOHC will be mated to an MT75, you really need to have a look to ID it.
Ketchup
i think the mt75 was fitted to the dohc and not the type 9, someone else will prob correct me tho
Guinness
posted on 23/9/07 at 08:35 AM Reply With Quote
The type 9 has a different gate pattern to the MT75. One has reverse below 5th and the other has reverse to the left of 1st. Can't help you with which one is which though!
Mike
t.j.
posted on 23/9/07 at 08:41 AM Reply With Quote
I'm using the dohc and it's def. the MT75
The MT75 is a Alu-casting
The T9 has a iron housing. (alu clutch-housing is possible)
Look in my photo-archive for picture of gear-box
Grtz
fesycresy
posted on 23/9/07 at 11:27 AM Reply With Quote
Just to throw a spanner in the works, I was talking to a guy who said he pulled a Type 9 out of a DOHC.
However I've just pulled an MT75 out of one and every one else seems to have one too.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 23/9/07 at 05:46 PM Reply With Quote
Yup, MT75 For the DOHC, i had one in my sierra donor.
Sporty
posted on 23/9/07 at 07:22 PM Reply With Quote
Thanks for the info. Though it was a bit cheap to be what i was looking for.
Ian
Durabang
posted on 6/10/07 at 08:10 PM Reply With Quote
MT75 also has the 'Lift' for reverse mechanism - the Type 9 is a 'Push down for reverse'
Duratec - Proved on track
Vindi_andy
posted on 25/4/08 at 11:34 AM Reply With Quote
MT75 on a twinky
lift for reverse positioned to left of 1st
chrisg
posted on 25/4/08 at 11:56 AM Reply With Quote
It's slightly confused by Ford using up parts by mixing and matching until all the type 9s had gone.
Working in a Ford dealers in the late eighties/early nineties, we once sold, in the same week two identical looking Sierra 2.0 GLs, one was a pinto with a type nine and the other a DOHC on a MT75. It was the same for the 1.6's, some were pinto, some CVH in no particular order.
I've even seen a 4 door RS2000 (mk2) which I would have put my house on not existing!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Schrodinger
posted on 26/4/08 at 05:39 PM Reply With Quote
I had a friend in the sixties who worked in a ford dealers and they took delivery of a 4 door Escort for a customer and did the delivery check on it and prepared it for him. Customer comes in and he is delighted with his brand spanking new car, goes out to the forecourt gets in it and comes back five minutes later asking why he has a three door?
It had two doors on the drivers side and one on the passenger side!!!
[Edited on 26/4/08 by Schrodinger]
Keith
Aviemore
