New Topic New Reply
Author: Subject: Tunnel access
scutter
posted on 27/9/07 at 07:10 AM Reply With Quote
Tunnel access
Morning all,
I'm planning on making the tunnel on my new build out of sheet metal.
Does anyone have any ideas or pitures on how to make the access panels for the gear lever and handbrake?
Also what structures will need to be included apart from a support for said handbrake?
ATB Dan.
RazMan
posted on 27/9/07 at 07:27 AM Reply With Quote
My central tunnel is made of 20mm box and the removable panels are held on with M4 rivnuts. Put a little sponge rubber tape under the panels to stop them rattling.
hth
Raz
worX
posted on 27/9/07 at 07:48 AM Reply With Quote
I would look at making the whole tunnel removable (if it's possible) rather than just access panels if I were you...
Agriv8
posted on 27/9/07 at 08:03 AM Reply With Quote
MNR's have a one peice GRP tunnel.
makes it nice and easy to remove for check diff bolts ( grease the sliding prop joints ect ).
regards
Agriv8
procomp
posted on 27/9/07 at 08:12 AM Reply With Quote
Hi correct me if i am wrong but is the original post talking about making the whole tunnel out of sheet as a structure rather than simply adding pannels to a frame.
Just wondering if i read it right. It has been done this way but cant think which kitcar it was.
cheers matt
MikeR
posted on 27/9/07 at 08:41 AM Reply With Quote
Isn't it similar to what caterham do?
Ivan
posted on 27/9/07 at 08:55 AM Reply With Quote
I also made my tunnel as a structural whole - initially it is very floppy with very little apparent strength but once welded in place is rock solid - to get to your question:
I cut out the necessary access holes (one for general access to gearbox and to help sliding in the prop shaft, the other for the gear lever) when the tunnel was tacked in place with gearbox and prop shaft installed, then removed it and welded in 25 X 2mm strips to act as an inside frame drilled for rivnuts. The cover sits in the frame where it's an access hole and the gearl lever glove will be bolted to the frame with a suitable polished cover piece.
If I find I need any other access I will just cut it out and weld it back when finished.
[Edited on 27/9/07 by Ivan]
posted on 27/9/07 at 10:03 AM Reply With Quote
^^^ wot ivan says.
also you may want to put some supports on the inside of the tunnel to hang loom, brake and fuel lines - these would need to be fitted from below, assuming to plan to run them in the tunnel.
funnily enouygh, I was thinking about this and rckon that if you know whaqt you are dong, you could make it lighter and as stiff as with square tubes and cover panels.
scutter
posted on 27/9/07 at 10:13 AM Reply With Quote
Matt, you're correct, the mods are listed as parts of cymtriks analysis and are suppose to help with chassis stiffness, but doesn't cutting a couple of holes in the sheet tunnel induce some weakness?
Now the choice is either square or rounded top and weldin or boltin?
ATB Dan.
Ivan
posted on 27/9/07 at 10:27 AM Reply With Quote
I chose the tunnel system based on Cymtrik's paper and welded it in because it's the lightest and strongest option.
If I could have worked out how to use Turbocad properly I would have drawn it out in cad and then unfolded it all and got it cut and folded by profesionals which would have been a whole lot neater and easier in the long run.
I really don't forsee the need to ever remove it once installed as it's easy to remove the engine compared to a tintop if ever you need to work on the gearbox.
And finally - as long as you properly frame the holes they dont weaken the structure significantly.
caber
posted on 27/9/07 at 10:46 AM Reply With Quote
If holes are in the centre of the panel they don't cgange the structure much, the sheet is basically triangulating so keep holes away from corners and you will be OK.
I am about to have to strip all my panelling off due to problems with propshaft and speedo censor
Caber
Alex B
posted on 27/9/07 at 04:40 PM Reply With Quote
Is prop hitting panels? If I have to strip mine off it will be with Plasma Cutter I have access top and bottom as I thought it would be enough.
Alex
zilspeed
posted on 27/9/07 at 04:47 PM Reply With Quote
regards
Agriv8
As does Ye Olde Sylva
scutter
posted on 27/9/07 at 05:15 PM Reply With Quote
Looks like bolt in wins
ATB Dan.
mojojeff
posted on 4/12/07 at 11:11 PM Reply With Quote
Sheet metal tunnel
Try McSorley he did CAD drawings + stress test, ended up lighter and stiffer. (was a while back tho'
scutter
posted on 4/12/07 at 11:33 PM Reply With Quote
Cheers Jeff, but i bottled it and made it out of 19mm round instead.
ATB Dan.
New Topic New Reply
