Author: Subject: sealing and painting MDF
jabbahutt
posted on 10/10/07 at 07:15 AM Reply With Quote
Morning all
Has anyone one here ever successfully painted MDF? I was going to cover the centre section of my dash in vinyl but there are a lot of small curves which I think will not easily cover and look good.
My next idea was to seal the MDF then spray in car paint. Has anyone here done this and if so what did you use to seal it and how well did the paint stick?
Many thanks
Nigel
John.Taylor
posted on 10/10/07 at 07:24 AM Reply With Quote
I made some speaker pods for my first car, a MK1 Fiesta, out of MDF. I mixed some PVA glue with water and painted it onto the MDF, let it dry/harden then used a can of grey spray paint from halfords to finish off. Paint stayed on al the time I had the car.
posted on 10/10/07 at 07:31 AM Reply With Quote
What he said... needs sealing first.
balidey
posted on 10/10/07 at 07:37 AM Reply With Quote
Melamine paint is perfect, covers and seals really well.
http://www.ronseal.co.uk/products/product.jsp?id=7
jabbahutt
posted on 10/10/07 at 07:40 AM Reply With Quote
cheers for the help. If sealing with a PVA/water mix is there a ratio to use like 50/50?
once i know this I can get out into the garage this morning and get cacking.
Thanks again for the asssitance
Nigel
StevieB
posted on 10/10/07 at 07:41 AM Reply With Quote
I'll second the melamine paint and matching sealent as said.
Use a sponge roller to put it on and it dries really nice and smooth. You can always rub it back between coats to get the best finish possible.
RazMan
posted on 10/10/07 at 07:50 AM Reply With Quote
Another votr for Melamine paint - works a treat.
Raz
JonBowden
posted on 10/10/07 at 08:02 AM Reply With Quote
I've used MDF primer in a few places in the house - seems to work ok
MDF primer at Screwfix
Jon
locoboy
posted on 10/10/07 at 08:04 AM Reply With Quote
agree to rubbing back as you get pin sized bubbles otherwise.
BTW it aint that scary a job you dont need to go and get 'cacking' in the garage lol
Locoboy
posted on 10/10/07 at 08:06 AM Reply With Quote
I've primed MDF with bog standard wood primer. Worked fine.
You'll need to seal the cut edges very well. MDF swells at the edges when it gets wet. On a car that's difficult to avoid...
I used ply in the end for my dash as MDF ain't the lightest product on the planet.....
James
posted on 10/10/07 at 10:10 AM Reply With Quote
I'm glad I'm not the only child on here who thought that amusing!!!
nige
posted on 10/10/07 at 10:34 AM Reply With Quote
mdf painting
i did some kitchen doors
pva , 50/50 sealed first
then mealamine primer rubbed down
then melamine gloss with a sponge
(gloss roller) excellent finish
well the wife said it was , so it must ave been
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
smart51
posted on 10/10/07 at 11:08 AM Reply With Quote
You could try some sanding sealer from timber yards or good DIY shops. Its used for sealing wood prior to polishing or varnishing.
Avoid anything "wet" as it will cause the MDF to swell.
gr8ging
posted on 10/10/07 at 11:50 AM Reply With Quote
I worked in a car body shop in New Zealand and we sprayed some kitchen units that had been made of mdf with normal car primer, flatened it back, another coat of primer, flatten back and then used gloss car paint. came out like a mirror, abeit black, with a bit of polish.
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
