Author: Subject: Filter Socks or remote filter ?
Jos Fury
posted on 10/10/07 at 05:47 PM Reply With Quote
Since I am going to fit an airbox around my throttle bodies I was thinking to put
filter socks over my trumpets. ( the pipercross sausage filter has to go since I do not have enough space ).
This means I only have to fit an intake hose to the airbox instead of an intake hose plus remote filter.
What do you think of the use of filter socks :
DIY Si
posted on 10/10/07 at 05:51 PM Reply With Quote
I'd go remote filter every time. The socks aren't as good since the amount of air they flow can be a bit low.
Sun Tzu, The Art of War
PaulBuz
posted on 10/10/07 at 05:54 PM Reply With Quote
i would fit a remote filter to the end of the pipe.
With your setup the air box could fill with debis around the socks, making it necessary to continually clean the box.
Of course I could be wrong, but its what i'd do!
Paul
jacko
posted on 10/10/07 at 06:40 PM Reply With Quote
hi i dont know if it will help you but if you look in my photos under zx9r carbs you will see how i did mine and i must say i have had no problems at all how they are
jacko
Jos Fury
posted on 10/10/07 at 07:13 PM Reply With Quote
Thanks for the tips. I will fit a remote filter as big as possible and get as much fresh air as possible. did not think about the box getting dirty all the time etc.will probably use this one :
connect a hose to it and at the end a funnel like this
well done jacko !
jacko
posted on 10/10/07 at 07:59 PM Reply With Quote
Thank you , i had two holes in my bonnet from when i had su carbs fitted so when i went to bike carbs i made the air box to suit the holes + added one in the middle
It has been like this for a year now and i have not had any problems+ no muck in the box
Jacko
Agriv8
posted on 10/10/07 at 08:20 PM Reply With Quote
remote and get some nice cool air can release a few more bhp as its denser so can add a bit more fuel in.
It will also mean that the sensors are reading the correct info.
regards
Agriv8
Jos Fury
posted on 11/10/07 at 07:36 AM Reply With Quote
after I finish the airbox the ecu will have to be remapped on the dyno. I use Throttle pos.sensor and no AFM / MAP so everytime I change something like air fuel I have to remap.
the temp.sensor is now positioned between the trumpets as so you can see.
this sensor will be put in the airbox to get the right data indeed Agriv8
Jos Fury
posted on 14/10/07 at 07:09 AM Reply With Quote
spent yesterday afternoon on the design af the airbox. will bring it to the welders tomorrow. if anyone is interested I can perhaps let them make two. guess it will cost around 100 euro or so. I know not cheap bit more locost than buying one.
[Edited on 14/10/07 by Jos Fury]
Stoo
posted on 14/10/07 at 05:26 PM Reply With Quote
I found the socks on my Tiger restricted the air flow and there was a noticebale performance difference.
That said does anyone know if the small single unit K&N style filters are the same? I'm just switching to bike carbs and was thinking about having a single small filter on each carb. I thought it would look cool but not sure if it would restrict the air flow or not?
Stoo
[Edited on 14/10/07 by Stoo]
