Author: Subject: Nuts
ady8077
posted on 16/10/07 at 09:29 PM Reply With Quote
Nuts
Hi all
Does anyone no wher to buy bighead style nuts in small quantities ?
RazMan
posted on 16/10/07 at 09:47 PM Reply With Quote
I don't think they have any UK distributors and only supply to the trade in appropriate quantities.
You might be able to blag some samples though - it worked for me
Raz
Chippy
posted on 16/10/07 at 10:23 PM Reply With Quote
Assume this is for bonding into GRP, if so fairly easy to make your own. Weld a nut onto the plate and drill a load of holes in it, I have used this method on boats, and it works just fine. HTH Ray.
takumi
posted on 17/10/07 at 07:56 AM Reply With Quote
Maybe worth getting some large alloy HEX bar, and cutting off pieces, and drill and tap a center hole to what ever you want..
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
Hammerhead
posted on 17/10/07 at 09:47 AM Reply With Quote
as Razman said, email tham and blag some samples, worked for me too!
Or make some, not very tricky.
