New Topic New Reply
Author: Subject: Looking for tube miter with a difference?
posted on 22/10/07 at 04:19 PM Reply With Quote
I've got the 'tube mitre' program on one of my PCs, and it is really good for shaping one round tube to fit onto another. You tell it the size of one tube, together with its wall thickness, the diameter of the other tube and the angle that they will meet. Once that's entered you can print out the shape, wrap it round the tube and cut-and-file it to get a near-perfect fit.
What I'm looking for is a similar program or method for printing the shape of a 30-degree cut across a tube, so that I can mark it out for sawing. In effect it's the same sort of thing, but in this case the 'second tube' is a flat plane.
If I had an old-fashioned drawing board with all the accessories I could project the shape, ready for cutting out... but I haven't, so I can't!
Can anyone offer a solution?
Ta,
jack trolley
posted on 22/10/07 at 04:43 PM Reply With Quote
Seem to recall someone suggesting using a H U G E diameter for one of the tubes
as an approximation of a flat plate.
Don't recall if it worked
posted on 22/10/07 at 05:16 PM Reply With Quote
I tried that...It doesn't!
It just gives a stupid shape that goes off the edge of the window...
Mark.
posted on 22/10/07 at 07:35 PM Reply With Quote
Use a protractor to start with but you can obviously only draw a wee line then use a bit of steel strapping or old tape measure to wrap around the tube along your scribed line....sounds nuts but it does work....honest.
Mark
Alan B
posted on 22/10/07 at 07:57 PM Reply With Quote
If you have solidworks or any solid modeller that does sheet metal you could model it as a folded up box section, then make the angled cut and get the developed (flat) shape and print out 1:1 as your template.
posted on 22/10/07 at 10:28 PM Reply With Quote
You want to make a straight 30* cut in a tube to fasten to a flat surface? Mark 30* on a square section and clamp your round bar to it while you cut through them both. I just set the chop saw to 30* though, it's easier
[Edited on 22/10/07 by Peteff]
jolson
posted on 23/10/07 at 08:45 PM Reply With Quote
I've got a program that'll do a tube against a flat plate. The only problem is that it doesn't print the template, instead producing a DXF file that you can fiddle with in your favourite CAD package.
screenshot
screenshot
John
posted on 23/10/07 at 09:59 PM Reply With Quote
Any chance of a copy of that? I can cope with DXF files - another bonus of Linux - free autocad-alike software!
NB: I do have access to a Win2K machine, if that's what the program needs!
907
posted on 23/10/07 at 10:15 PM Reply With Quote
If you get stuck I'll get my compass out and see what develops.
Sorry but I'm still in the 20th century.
Paul G
posted on 23/10/07 at 10:16 PM Reply With Quote
...I was going to make a rude and flippant comment then - but I still want you to weld up my manifold!
907
posted on 23/10/07 at 10:22 PM Reply With Quote
Think I'd better check to see if I still have lead in my pencil.
Paul G
chrisg
posted on 24/10/07 at 01:14 PM Reply With Quote
I'd like a copy if possible too, please.
Chers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Fred W B
posted on 24/10/07 at 01:38 PM Reply With Quote
I'm lost - If the tube you are cutting already exists as a tube just cut it straight through on a flat plane?
Differnt story if you want to develop a flat pattern to cut a plate before you roll it up into a tube though
Fred W B
posted on 24/10/07 at 02:54 PM Reply With Quote
Fred - I'll get you a map!
The only reason is that I will have to use a hacksaw to cut the tube, and I wanted to make some guide marks so that I didn't stray off-line too much, while still cutting at the correct angle.
If I had a bandsaw or similar tool I wouldn't be asking this question...
Alan B
posted on 24/10/07 at 04:36 PM Reply With Quote
Chers
Chris
Me too if possible....
Alan
posted on 24/10/07 at 04:52 PM Reply With Quote
UPDATE:
I tried the program - it works! The output is a DXF file, and it's a bit small when printed - but that is most likely to be due to me using Linux, QCaD, and not knowing how to get the scaling right!
I shall persevere...
posted on 24/10/07 at 06:03 PM Reply With Quote
Can't help with a program David but have you thought about using a mitre saw with a metal cutting blade?
posted on 24/10/07 at 06:43 PM Reply With Quote
That's what I'm doing at the moment - got one of B&Q's finest yesterday!
paulf
posted on 24/10/07 at 09:12 PM Reply With Quote
I just used a combination set and put the tube in the vice, then eyed up my hacksaw against the combination set and vice jaw.
Cut it as near as I could and trimmed the end with a file to get final fit.
Paul.
cjtheman
posted on 24/10/07 at 11:19 PM Reply With Quote
hi
a good cheap bit of kit for that its called a line of chords
its a 2 ft folding steel rule
it has all angles on reverse side
all you need to go with it is a set of deviders
it has two centre pop marks on it
set the deviders to correct angle
fold the rule until line up with centre pops and the rule will give you correct angle
they cost about £12 from good tool shop
they work good enough to make staircases with in work
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
jolson
posted on 25/10/07 at 08:41 PM Reply With Quote
I put a copy of the program up at http://www.talkingmonkey.co.uk/tubexp.exe, but it's just the executable. If you don't already have the VB common dialog routines on your machine, it won't run. I'll try to organise a properly installing version on the weekend.
John
New Topic New Reply
