Ferrino
| posted on 22/10/07 at 08:40 PM |
Storage and BEC Carbs
My BEC 7 is having to go into storage for seven months or so and I will be away from it during this time (ie. won't be able to start it
periodically or anything).
I was therefore wondering what you guys recommended doing to the car before I put it into hibernation (it's going to live in a nice cosy
garage)?
It is a carbed '99 R1, should I consider draining the fuel from the carbs or just leave them be?
Thanks so much!
Jon Ison
| posted on 22/10/07 at 08:50 PM |
Defo drain the fuel.
worX
| posted on 22/10/07 at 08:57 PM |
I've never had to do this myself, but would it be a good idea to disconnect the fuel line and run it until it stops, then dropping the float
bowls?
Or would it be best just to strip the carbs off it and down altogether?
remove the plugs and put a bit of oil into the cylinders from above, then refit the plugs.
An oil change when you get back.
Don't leave the hand brake on.
Set the car up on axle stands to preserve the tyres.
That should do it.
smart51
| posted on 22/10/07 at 09:03 PM |
You don't need to remove the float bowls to drain them. You just need a 5mm allen key to loosen the drain bolts.
UncleFista
| posted on 22/10/07 at 09:19 PM |
Sod all that malarky, just leave it with me while you're away, I'll make sure your petrol doesn't go "off", hell,
I'll even contribute a (small) percentage of the fuel costs and you won't need to touch a screwdriver
Tony Bond / UncleFista
Ferrino
| posted on 22/10/07 at 10:57 PM |
Great, thanks. I will drain the carbs then.
Just went out to check how much fuel was left in the tank and there is a good 20 litres! I can't be arsed to remove the tank and tip it out - is
it safe to just disconnect the fuel line from the carbs and run it into a jerry can for the tintop (as suggested)? I guess I just need to make sure I
cut off the pump as soon as it empties! Cheers again!
| posted on 23/10/07 at 07:39 AM |
Maybe there's a gap in the market for a new service here
awinter
| posted on 23/10/07 at 08:38 AM |
put some fuel preserver in it and it won't go off.
| posted on 23/10/07 at 09:33 AM |
Fuel preserve/octane booster and if you oil the bores, turn the engine over with the plugs out and don't refit your iridiums, put some old plugs
in for the restart or fit new ones after it. This
stuff from MM will do it.
kastrato
| posted on 23/10/07 at 09:44 AM |
Disconnect the battery too. Leave the tank with petrol in to prevent it from rust.
I have left mine in greece for the winter the only thing I did was to raise it up on tripodes (stands) and taken the wheels off. I disconnect the
battery and I left the flouids all in to prevent rust and protect it from cold (refering on the cold days is better the fluids to be in the radiator
etc)
Talking about carbs I didn't do anything but I hear that you need to drain them. Can somebody explain to me why this is necessary to be done?
MK INDY fireblade
Coose
| posted on 23/10/07 at 01:49 PM |
The petrol tends to evaporate out of the carbs and leaves a residue which will cause untold problems, blocking jets and emulsion tubes etc.
Do as above: -
Drain the carbs,
Squirt of oil down each bore and give it a momentary prod on the starter with the plugs out,
Disconnect the battery or buy an Optimate,
If it's an ali tank it obviously wont rust, but if it's a steel one it may. If steel, a touch of two stroke oil in the fuel and a good
slosh around will help, but remember to drain the fuel out before you restart it or it'll end up smelling too nice! Oh, and you'll think
that there's something wrong as there'll be a hint of blue smoke out of the chimberley until you flush it out of the tank!
Axle stands isn't a bad idea, but put them under the chassis and not the wishbones.
Change the brake fluid before you bring it back out again.
Other than that, all should be fine!
Spin 'er off Well...
kastrato
| posted on 23/10/07 at 04:24 PM |
I didn't drain the carbs and I did put the axle stand under the wishbones.
How much damage can happend by these until xmass which is where I will go to the car again (Greece) and do them properly (drain the carbs and place
the axle stands under the chassis)
How do I drain the carbs?
MK INDY fireblade
Ferrino
| posted on 23/10/07 at 04:58 PM |
Thanks - will drain carbs and do the oil squirt trick! It's an ali tank so no worries there - I think I will tip in some of this 'fuel
preserver' rather than emptying the tank with the pump, if you guys think it will be OK...
