Author: Subject: How to get this sticky stuff off?
westcost1
posted on 5/11/07 at 01:20 PM Reply With Quote
Hi just a quick question What is the best stuff to use to take the sticky residue of the side of a van after the vinyl sign writing has been removed? I used paint brush cleaner to get some off my fibreglass body work but this will obviously remove the paint from the van so is not suitable. I did use polish / tcut once to remove pin stripes but it took a long time. So any other ideas? Im hoping that if I heat up the vinyl with a hair dryer before removing it there won’t be to much left on there but im shore some sticky will stubborn.
locoboy
posted on 5/11/07 at 01:27 PM Reply With Quote
Gelsol from autosmart is what we used to use when we de-lettered our vehicles.
Also usefull is a starbrite distributed product called tar and glue remover. (www.starbrite.co.uk) go to car and automotive, then cleaners (exterior) and its the last one on the page,
Both good in my experience.
[Edited on 5/11/07 by locoboy]
Locoboy
Bluemoon
posted on 5/11/07 at 01:32 PM Reply With Quote
WD 40? or apparently you could try baby oil..
WD 40 worked for me on adhesive from masking tape..
Dan
iank
I've successfully used isopropyl alcohol for the job. There's been a thread about this before:
http://www.locostbuilders.co.uk/viewthread.php?tid=42283
So just about any solvent
Anonymous
westcost1
posted on 5/11/07 at 01:36 PM Reply With Quote
thanks so do you think any old tar remover from halfords would do the trick?
thanks guys i have just got back from maplins aswell dow!
[Edited on 5/11/07 by westcost1]
izzy alright
posted on 5/11/07 at 01:52 PM Reply With Quote
Try acetone .£1.00 from any chemist. Izzy
westcost1
posted on 5/11/07 at 02:05 PM Reply With Quote
acetone will remove the pant as well?
gezer
posted on 5/11/07 at 02:32 PM Reply With Quote
try methylated spirit
I'm to old to live and to young to die --- buggerit
RickRick
posted on 5/11/07 at 02:41 PM Reply With Quote
autoglym tar spot remover worked for me, but it's not cheap
westcost1
posted on 5/11/07 at 02:53 PM Reply With Quote
Thats ok its the boss paying for it so it dusnt have to be locost
DarrenW
posted on 5/11/07 at 03:16 PM Reply With Quote
Ive used panel wipe before. Try a test area first.
posted on 5/11/07 at 03:34 PM Reply With Quote
I use cellulose thinners or acetone, it won't remove hardened paint only fresh stuff.
RazMan
posted on 5/11/07 at 04:14 PM Reply With Quote
Try white spirit or meths
Raz
speedyxjs
posted on 5/11/07 at 04:22 PM Reply With Quote
White spirit or just go to your local sign writing place and ask them. They should do it for free
stevec
posted on 5/11/07 at 04:42 PM Reply With Quote
Mr Sheen.
Guinness
posted on 5/11/07 at 05:03 PM Reply With Quote
Originally posted by stevec
Mr Sheen.
Charlie, Martin or Barry?
Mike
stevec
posted on 5/11/07 at 05:56 PM Reply With Quote
Mr Sheen.
Mike
Danozeman
posted on 5/11/07 at 06:33 PM Reply With Quote
Meths turps or white spirit. Petrol is quite good also.
Dan
madrallysport
posted on 5/11/07 at 06:38 PM Reply With Quote
When I remove stickers of the rally car, I remove any sticky left overs, with a rag with a bit of petrol on it, works a treat, and there's always a wee bit of petrol to use at the bottom of the jerry can.
[Edited on 5/11/07 by madrallysport]
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
