Author: Subject: Catalytic Converter
Skirrow
posted on 5/11/07 at 08:14 PM Reply With Quote
Catalytic Converter
Can anyone help me with this one?
My donor is from '93 but was fitted with a cat.
Does that mean that if I get an age related plate it will subject to the advanced emissions test at either MOT or SVA stage? Or are they not bothered about whether it was fitted with a cat but just interested in the age (in which case I think I am ok aren't i?)
And what if it gets a Q plate, are the rules the same?
Cheers!
Optimum Balance Products
posted on 5/11/07 at 09:24 PM Reply With Quote
Hi, i am sure on a Q plate you will be exempt with the MOT.
However SVA will likely require a Cat. Give your local MOT station a call, they should be able to confirm the MOT.
Things are always changing and it will depend on what paper work you have to give to the SVA.
I hope this has helped.
Regards
Grant.
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site www.obpltd.com
Thank you for your time.
All the best,
Obp Ltd.
Skirrow
posted on 8/11/07 at 06:00 PM Reply With Quote
Cheers Grant, how come SVA require it, is it because it originally had one or because it's after a certain year?
Just trying to figure out f there is a way round it (without using a different engine)
matt_claydon
posted on 9/11/07 at 08:47 AM Reply With Quote
You need proof from the vehicle manufacturer of the engine's age. Since it's '93 you will not require a cat for SVA. It is irrelevant what the donor vehicle had fitted.
For MOT you will then need to pass a 'non-cat' emissions test if you get an age-related plate or a 'visual smoke' test if you get a Q.
Skirrow
posted on 9/11/07 at 06:59 PM Reply With Quote
Cheers! That's better news, and the answer I was hoping for.
I take it I can just write to Rover with the engine number and they will sent a letter proving the age?
matt_claydon
posted on 10/11/07 at 05:09 PM Reply With Quote
That works with Ford, not sure about Rover (not least because they don't exist any more!). The owners club could do it but you'd have to check with your SVA station that they would accept that.
THE BEAR
posted on 12/11/07 at 04:25 PM Reply With Quote
what about a 1999 zetec black top will that need a cat for the sva
Skirrow
posted on 12/11/07 at 07:40 PM Reply With Quote
Cheers Matt, not sure how I will go on with Rover, although I'm sure one of the Mini guys will know.
The bear, I think everything after '95 has to have a cat. Well, it doesn't have to have a cat technically, but it does have to pass the advanced emissions test which is gonna be very difficult without one I am told.
stevebubs
posted on 18/11/07 at 10:26 PM Reply With Quote
yes
