Author: Subject: Rusty cortina hubs
ELO
posted on 7/11/07 at 04:32 PM Reply With Quote
Rusty cortina hubs
Hey folks,
Need a bit of advice... I don't want to sound like a complete burke but I can't seem to get the discs off the rusty cortina hubs I've got.
(I hope to replace them with some new ones - which reminds me I need to speak to Razman...)
I've spent the last few days undoing some very rusty bolts (with the help of Mr Lump Hammer ) but now can't figure out what to do! No matter what I do the discs are stuck tight.... so what have I forgotten to do / undo !?
ed
Paul TigerB6
posted on 7/11/07 at 04:45 PM Reply With Quote
I had a similar problem with a set of Mondeo disks on my friends car. Turned out there was so much corrosion on the hub face / disk that no amount of hammering would remove it. I had limited resources with me at her house and ended up using Mr Angry Grinder / chisel on it.
Guess you could try soaking in penetrating oil or lots of heat on the disk followed by a few whacks with a large hammer
posted on 7/11/07 at 04:51 PM Reply With Quote
heat, heat and more heat followed by a sound beating with your biggest hammer I reckon
Mal
posted on 7/11/07 at 05:00 PM Reply With Quote
Try pouring a kettle full of boiling water over the joint area. Leave for a couple minutes and then hit it.
I have fo it often works.
Mal
posted on 7/11/07 at 05:16 PM Reply With Quote
WOW.. This is the third time today I've recommended electrolysis.
It will remove all the corrosion and allow the parts to separate.
Get on the bus!!
http://locostbuilders.co.uk/viewthread.php?tid=9158
Paul TigerB6
posted on 7/11/07 at 05:41 PM Reply With Quote
Will electrolysis remove rust thats formed between the hub and disks though as i thought it worked more "line of sight"??
Could be a useful way to remove rusted in bolts etc if it does!!
repper
posted on 7/11/07 at 05:48 PM Reply With Quote
when i stripped my hubs i was told by a mate to go to halfords and some rust off
its made by hammerite and called rust remover you can get it in gell or lickwid and you mix with water just mix togather and leve to sook the longer you leev it the better it comes out my front hubs went from orange rust to shiney silver its not cheep but it works mint
thunderace
posted on 7/11/07 at 06:09 PM Reply With Quote
http://www.youtube.com/watch?v=R5I5WBG5HPw
chasmon
posted on 7/11/07 at 06:16 PM Reply With Quote
I have had discs on a car do the same.
I chain drilled holes from one edge to the centre being careful to use a depth stop and not damage the hub. Then angle grind or dremel to join them up into a slot. Doesn't have to be all the way through at the hub.
Next get your lump hammer and a masonry chisel and split them.
I had a mare with the mundano ones and the first one took hours. second one took under 30 mins with this method
posted on 7/11/07 at 07:05 PM Reply With Quote
Yep, electrolysis gets in everywhere. It will destroy the rust in between the parts and is very good at freeing up rusted fasteners.
Forgot to mention, its virtually free and there's no effort required.
[Edited on 7/11/07 by coozer]
repper
posted on 7/11/07 at 07:20 PM Reply With Quote
that worked mint but noing my look ide blow put the house oy my sen
posted on 7/11/07 at 08:09 PM Reply With Quote
Eh?? What the hells that all about?
triafgg
posted on 7/11/07 at 09:14 PM Reply With Quote
Beats me!!!
DarrenW
posted on 7/11/07 at 09:19 PM Reply With Quote
Ive also had mondeo disc trouble before - angry grinder worked a treat.
Electrolysis is worth a try first especially if you want rust free hubs to fit.
I had my mondeo hubs (and other bits) pro stripped and zinc plated.
Paul TigerB6
posted on 7/11/07 at 10:27 PM Reply With Quote
I'll have a pint of what he's drinking please
WanchaiWarrior
posted on 7/11/07 at 10:50 PM Reply With Quote
That works ok, but knowing my luck I'd blow up the house on my ??????????? perhaps ???
bigrich
posted on 7/11/07 at 11:28 PM Reply With Quote
sen is a yorkshireism for own or self
by mi sen on my own, by my self
so he may blow up the house on his own
ELO
posted on 8/11/07 at 08:59 PM Reply With Quote
Hey guys,
Thanks for the replies.
Got some of that Rust Remover from Halfords as Big Hammer didn't work.
I think I'm going to have to look into this electrolysis business - after spending a number of hours this week loosing arguments with rusty bolts (even when armed with with spanners and the lump hammer) I like the lack of effort required!
ed
