milton
posted on 15/11/07 at 08:17 PM |
over charging
a friend of mine is looking at a bike engined lowcost but seller says that it over charging what is solution ??will it be expensive neither of us
knows anything about bike engines.
cheers.
[Edited on 15/11/07 by milton]
andrew.carwithen
posted on 15/11/07 at 08:28 PM |
Firstly, what bike engine is it? (if its a fireblade could be relatively simple fix)
[Edited on 15/11/07 by andrew.carwithen]
dan__wright
posted on 15/11/07 at 08:50 PM |
probably regulator / rectifier
FREE THE ROADSTER ONE…!!
milton
posted on 15/11/07 at 08:57 PM |
charging
sorry dont know will find out.
cheers.
posted on 15/11/07 at 10:40 PM |
Likely the regulator- quite a common failure on BECs.
On some charging circuits if the battery goes TU the voltage goes stupidly high so there's an outside chance its the battery not the regulator
(but its less likely).
shortie
posted on 15/11/07 at 11:04 PM |
Firstly check what he means by overcharging, the battery on a BEC will show between 14-15 volts when the engine is running.
If it's more than this then it is most likely to be the regulator\rectifier and it will be pretty simple to change so no big issue.
HTH,
Rich.
[Edited on 15/11/07 by shortie]
