Author: Subject: Andy Bates - Just plain wrong?! [Soapbox Warning!]
TimC
posted on 20/11/07 at 02:23 PM Reply With Quote
Before I go any further, let me just say that I think AB Performance are a fine company and if I was going racing and wanted a 'Blade engine, that's where I'd go. Now that I can't be accused of any nonsense, allow me to continue...
Just nipped to Tesco for a sandwich. Thought I'd have a quick flick through the magazine section. "Ooooo, a new Total Kit Car" says I. So I look at the cover and see that there's a Bike Engine Guide. I must admit that at this stage, I expected some poorly written, poorly informed garbage from some hack. I turn to the page anyway and find that the Andy Bates of AB Performance has contributed to the article - excellent - or so I thought.
Andy has rated all of the usual suspects in terms of engines out of 10. Fair enough. I know that Andy is something of a Honda Guru so expected a high score for the carb'd blade engine and I was not suprised = 9.5/10 for 893 and 10/10 for what the magazine calls the 918, but I thought was 919. Anyway, fair enough - it's well proven and easy to install. So I turn to the page for Yamaha to look at the R1 - 7/10 - are you mad?
Naturally I am biased, but I obviously took my decision on the engine on the basis of real data. How can you give the 'Blade which produces 130bhp from 62kgs 10/10 but only give the 5JJ R1, which produces 160bhp from a similarly light engine, 7?
I admit that the R1 is a little more complicated to plumb-in but surely 30bhp is reward enough. It's not even that the R1 has a reputation for going pop like some other motors when turned through 90degrees.
Can anyone give me a reasonable explanation?
Annnnnnnnd..... relax.
worX
posted on 20/11/07 at 02:38 PM Reply With Quote
err, No ?
That boy just likes his Blades!!!
Pinto?
Edit to say...
Sorry that's not really very constructive is it
[Edited on 20/11/07 by nick205]
r1_pete
posted on 20/11/07 at 02:52 PM Reply With Quote
Intertesting, I've got both (in bikes) a 2001 R1 and a 1996 blade yes it is definately 918cc. The R1 is faster, more responsive, and far more focussed.
Not saying the blade is bad, but there is 6 years between the two engines, in response to the R1 and GSXR thou, Honda completely revamped the Fireblade, draw your own conclusion.
Cant vouch for car use but IMHO the Yamaha motor should win hands down over the 918 Honda engine. One factor he may or may not have referred to is the fact that R1 gearboxes have been known to pop, but by the 2001 / 2 final carb models, that was sorted.
Rgds.
Pete.
the_fbi
posted on 20/11/07 at 04:04 PM Reply With Quote
My 919 has 919 stamped on the end of the head, although I see people calling them 918's all the time, no idea why.
Surely if Andy was riding a Honda engined bike & sidecar and winning everything, the Fireblade must be a better engine than the R1?
If the R1 engine bike & sidecars were winning then it would prove otherwise.....
stuart_g
posted on 20/11/07 at 04:15 PM Reply With Quote
I don't know the bloke or anything to do with his business but if he's a Honda man and does Honda engines why would he say the Yam is better? People would ring him up and ask for Yam engines and he'd have to say "Err sorry we do Honda"....doh!
posted on 20/11/07 at 04:24 PM Reply With Quote
I guess it really depends on the criteria against which it was being judged.
At 454.2 lb and putting out approximately 124 horsepower from its inline 4 cylinder engine, the original Fireblade defined a new genre - big displacement bikes that were as light as, if not lighter than, their 600 cc counterparts.
It had the best power/weight ratio of any bike engine for two years, from 1992 until 1994 when the ZX9R was introduced and the Fireblade pioneered meticulous attention to weight-saving design in bike engines.
Personally, I still reckon the 893 and 918 Blade engine is one of the easiest BEC installs and even the earliest engines are still highly desirable. I reckon Andy got it right.
Phil
[Edited on 20-11-07 by Hellfire]
Avoneer
posted on 20/11/07 at 05:09 PM Reply With Quote
It's only HIS opinion anyway.
Pat...
bigrich
posted on 20/11/07 at 05:31 PM Reply With Quote
seen more R1 motors with holes in crankcases etc than blades, also r1 use more oil so for me they are a more fragile albeit powerful engine so i would agree with Andy
r1_pete
posted on 20/11/07 at 05:33 PM Reply With Quote
You sure its not a 929, specs were 1992 - 95 893cc, 96-99 918cc, 2000 - 01 929cc, 2002 - 03 954cc, 2004 on 998cc.
ChrisGamlin
posted on 20/11/07 at 06:30 PM Reply With Quote
All of my 919's had err 919cc on the block
Tim, are you sure the review isn't in the context of the RGB, in that the R1 kinda sits in the middle of the regs and so isn't ideal for any class?
Ill gracefully bow out now though having upgraded from the 10/10 engine to the 7/10 engine (or more accurately the later 5PW brother of the JJ).
Chris
[Edited on 20/11/07 by ChrisGamlin]
the_fbi
posted on 20/11/07 at 07:03 PM Reply With Quote
Nope, as my other one is a 954 with 954 on the side.
Snippet from the Honda technical manual below...
919 specs
919 specs
Andy B
posted on 20/11/07 at 08:45 PM Reply With Quote
Bike engine article
Oops
thought I had better step up to the plate and explain myself re this article so here goes -
I was asked for my honest opinion re the various bike options available based on cost, reliability, ease of install, running costs and build quality. So it really wasnt just a power / weight thing.
Contrary to popular belief we dont just do Hondas here and I have supplied, stripped, rebuilt and installed most of the modern Japanese 4's, in fact up until I wrote it off I had an injected R1 Fury which I thought was a cracking car.
Based on the criteria I was given and the fact that 90% of my kit ends up racing I still wholeheartedly believe that the carbed blade really is the ultimate all rounder.
I used to run fully tuned 160bhp carbed blades in the sidecars, my original motor did 2 seasons, won 3 championships and after I sold it did 3 more seasons without coming out of the bike, I know for a fact that the R1's just could not compete with that level of reliability in fact despite the temptation of the extra horsepower it is that reason alone that we stayed with the blade.
All that said I in no way wished to offend owners of the R1 engine it was just my opinion.
Having raced bikes most of my life and indeed nearly ended my life on them I still get a massive buzz from them, I wanted the article to be a useful guide to the issues surrounding BEC's, it was not my intention to be controversial and I hope that my opinions do not detract from the article.
Hope that has helped explain things
regards
progers
posted on 20/11/07 at 09:06 PM Reply With Quote
Let me first say that Andy B is a fine chap (who I know well) and he has as valid a point as anyone when it comes to bike engines (more so than most). He in fact looks after my engines...
However, in this case I think Andys opinion is slightly coloured. I think this is due to a couple of reasons
1) Blades are his first love
2) R1's are more of a pain in the arse to strip and rebuild
3) 2004 -> R1's have had issues with blowing out their oil and going bang.
In reality the 5JJ and 5PW R1's are actually a great reliable engine. They have a much more robust gearbox than that of the blade and (in common with blades) don't suffer from oil surge with a good baffle plate. In RGB racing I (and Paul Haynes before me) have raced a full season without touching the engine at all which can't be said for 50% of the field that run blades. Maybe I've just been lucky.
All in all its down to personal opinion. Blades are a great engine, no doubt, but given the choice between it and a more modern, powerful, R1 I would not hesitate to choose the R1. Having built 2 cars with R1 engines (5JJ and 5PW) I'm also a bit biased
Paul
yorkshire-engines
posted on 20/11/07 at 09:26 PM Reply With Quote
Having chased Andy round most race tracks for a few years (never caught him either) i can say his blade engines were really quick and thats why he loves them
you may find that i dont advertise a lot of early blade motors thats because Andy already has his name on them as soon as i get them
anyway there all bloody quick
ill let you know what the 07 R1 is like very soon
cheers malc
ChrisGamlin
posted on 20/11/07 at 09:27 PM Reply With Quote
Out of interest Tim / Andy, what rating did the other engines get?
Having had both in my car, thus far its a score draw on failures. Although Ive had two blade failures, one of those was my fault, the other though broke up its crank / clutch primary reduction gear which was an odd failure.
Having fitted my third blade, I eventually decided to upgrade from blade to R1 partly because of the performance increase, and also because I had concerns over the longevity of the blade gearbox / clutch rather than the engine itself, having had clutch slip issues myself on a couple of occasions and heard quite a few stories at the time of gearboxes going due to bent forks / rounded dogs etc.
Having installed the R1, first impressions were that the clutch and gearbox felt more robust and nicer to use, and the drivetrain did feel a bit less on its design limits than the blade, to me anyway. Ironically though, the gearbox was the part that actually went in my engine, but again a slightly obscure failure in that it was the 5th gear dogs that were completely sheared off on a fairly unhurried downchange from 6th, not the lower gears that usually get more shock loading
Anyway, mine will be off up to Andy to get rebuilt once I source an 02/03 gearbox, so if anyone has one, let me know.
cheers
Chris
Asterix
posted on 20/11/07 at 11:18 PM Reply With Quote
i think ab has observed more failure rates in yams than hondas
Aint 53.78/ Cadw 96.39/ Crof 97/ CurbL1 37.01/ CurbL2 81.? wet/ Heth 82.34 kaput/ Loto tba/ Shel 41.4 wet/ Thor 56.36/ Tycr 129.52
Sponsors... Pets Testing Webhosting
scoobyis2cool
posted on 20/11/07 at 11:54 PM Reply With Quote
At one time I was considering converting my Indy to a BEC and did a lot of research into the various engines and the R1 came out top of my list - 7/10? Pah!
Pete
TimC
posted on 21/11/07 at 01:05 PM Reply With Quote
Just been for a quick look:
Carb'd 'Bird =8 (Ka-boom)
ZX12 = 9
Busa = 10
GSXR1000 = 9 (Ka-blammo)
Therfore cobblers.
