Author: Subject: Velocity chassis size
Jonas
posted on 3/12/07 at 08:54 AM Reply With Quote
Hi!
Is the Velocity chassis size the same as the book chassis?
Would the bodywork made for locost/book chassis fit a Velocity?
twybrow
posted on 3/12/07 at 09:43 AM Reply With Quote
As far as I know they are very nearly the same. I am fitting Velocity bodywork to a Stuart taylor (pretty much the book chassis) and everything seems to fit apart from the rear panel, which will have to be modified slightly to fit.
wilkingj
I believe its th same size as Book,
However the bodywork is approx 2" taller to accomodate Pinto Engines.
However I am not 100% sure.
My Viento body definately would not fit
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 3/12/07 at 07:05 PM Reply With Quote
IIRC Danzoman is fitting Velocity body panels to a Luego locost chassis
motivation cars
posted on 4/12/07 at 11:17 AM Reply With Quote
the size of the locost and the velocity xt is the same i should know they are built on the same jig
joe
Jonas
posted on 4/12/07 at 02:24 PM Reply With Quote
Thanks for the answers!
So the Velocity body (nose, shutle and bonnet) is higher than a locost body, but the chassis has the same dimensions?
Also, has there been a model named only "Velocity" or is "Velocity" and "Velocity XT" the same?
motivation cars
posted on 4/12/07 at 05:10 PM Reply With Quote
the only one that is done is the xt which is xtra track width
joe
