Author: Subject: electronic speedo
gy351100
posted on 9/12/07 at 11:17 PM Reply With Quote
electronic speedo
hi all
due to the lack of space for a normal speedo cable, i want to fit an electronoc speedo.
i need advice on what sensor and associated gear to use including the speedo.
the "toothed wheel " for the sensor i can make.
cheers
keith
thunderace
posted on 9/12/07 at 11:39 PM Reply With Quote
i got this one koso
ebay
Item number: 270194364436
or you could buy this 95p
BICYCLE ODOMETER BIKE CYCLING COMPUTER SPEEDOMETER
Item number: 150192645321
Mr Whippy
posted on 10/12/07 at 12:21 AM Reply With Quote
I think the SVA requires that the odometer cannot be simply reset at the push of a button as some simple bike ones can also should be quite accurate. You don't need a toothed wheel, just a reed switch and a magnet that's attached to either the prop shaft or more commonly the inside of the cars wheel.
[Edited on 10/12/07 by Mr Whippy]
posted on 10/12/07 at 08:45 AM Reply With Quote
Different speedos have different sensor requirements.
The easiest to install are those based on stick-on magnets. Simply attach the magnets to suitable (propshaft is popular) and attach the sensor to a little bracket.
Toothed wheels are usually used with VR (variable reluctance) sensors. Trouble is you need an air-gap of typically <1mm, which means the bracket etc has to be pretty solidly made...
posted on 10/12/07 at 09:54 AM Reply With Quote
No odometer requirements for SVA, just the speedometer must not read under your actual speed. Some leeway is allowed in the other direction
posted on 10/12/07 at 12:26 PM Reply With Quote
bicylce speedo can be made to work - I passed SVA with one - magnet mounted in one of the holes of the rear drive flange, croe plug fashion.
they need to be illuminated.
a proper electronic speedo - dial with pointer like mechanical ones use a number of different sensors - reluactance or reed swtich - depending on model. you can buy the sender to match the speedo for around £ 30.
(I will be making my own for a Racetach speedo).
hellier0437
posted on 12/12/07 at 08:18 PM Reply With Quote
do all the bicycle speedos work at high speed?
posted on 13/12/07 at 09:25 AM Reply With Quote
good question; a lot have 2 digit display that would limit you to 99 mph - try doiongthat on a bike. best to keep the receipt when buying!
hellier0437
posted on 14/12/07 at 09:46 AM Reply With Quote
just wondering whether anyone had any ideas about how to fulfill the requirement for the speedo to be lit if i were t use a bicycle speedo
thanks
