Author: Subject: rear uprights / bushes
jamrogers
posted on 12/12/07 at 06:33 PM Reply With Quote
I've assembled the rear uprights and when tightening the upper bolt on the upright the bracket on the top of the wishbone bends in, i've got the full kit from tiger but can't find a spacer.... do i need to machine one up? Rescued attachment DSCF0030.JPG
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
Mr Whippy
posted on 12/12/07 at 06:46 PM Reply With Quote
washer?
Mr Whippy
posted on 12/12/07 at 06:48 PM Reply With Quote
are you saying that is the bolt in the middle and not a piece of tube?
jamrogers
posted on 12/12/07 at 07:08 PM Reply With Quote
i know it needs a washer its only loosly assembled, what i want to know is should the kit come with a spare piece of tube/ spacer to stop it bending in or do i need to make one up
YouTube
bonzoronnie
posted on 12/12/07 at 07:18 PM Reply With Quote
Crush tube
Looking at your photo. Yes you will need a crush tube for the middle section.
You'll not tighten the bolt without one.
Ronnie
fideel109
posted on 12/12/07 at 07:31 PM Reply With Quote
During the build you'll find out that you will be looking for a lot of other parts...
But that's part of the game, and it always gives satisfaction when you find a cheap solution to a problem.
And to build an Avon you do need some imagination.
cheers-JP
Ricks-9r
posted on 12/12/07 at 07:38 PM Reply With Quote
a short length of aluminium tubing should do the trick
Ian D
posted on 12/12/07 at 08:10 PM Reply With Quote
It caught me out as well I used some washers. I also bought some longer bolts. As there was barely a thread showing. Yours looks short too in the picture.
Hope this helps
ian
timex
posted on 12/12/07 at 09:38 PM Reply With Quote
I may be wong but cant you just use two bolts instead of that one wich goes right through???
jamrogers
posted on 12/12/07 at 09:41 PM Reply With Quote
you prob could use 2 bolts but it wouldn't be as strong.... i'll get some tube from somewhere i think...... cheers guys
YouTube
Black Cat
posted on 12/12/07 at 11:06 PM Reply With Quote
I used stainless steel tube which I obtained from a boat yard.
James
posted on 13/12/07 at 01:07 AM Reply With Quote
Clearly I'm no expert on suspension design or shear loads but isn't that a 'kin daft way of doing it?
Why have twin bushes then connect them to only one side of the bracket each.
Might aswell have only one bush in the style of MK might you not?
But what do I know!!!
James
Mr Whippy
posted on 13/12/07 at 08:00 AM Reply With Quote
Yeah I'm not all that impressed by that design either, a bit pointless plus the MK version is adjustable for camber.
Nice welds though
James
[Edited on 13/12/07 by Mr Whippy]
DaveFJ
posted on 13/12/07 at 09:24 AM Reply With Quote
yup - I used a length of stainless tube from B&Q....
you will also need to pack out the lower inboard rose joints with washers - I have set mine to the position that they naturally wanted to sit but they may need adjusting later....
Dave
