Author: Subject: Engine n' box
focijohn
posted on 16/12/07 at 06:33 PM Reply With Quote
Engine n' box
Hi all,
Still deciding what to buy, but more of a problem is the engine + gearbox I have a select few which are:
1) 4AGE 1600 16v or if i can afford it a 20v and bolt a s/c on once ive stopped scaring myself.
2)2.0 Zetec
3)1.8 Zetec
I was originally going to put a 2.0 Zetec in but was "informed" (roughly) the input shaft on the type 9 was too short or long, but i was under the impression that the 1800 and 2.0 zetec's were of the last ford derived engines i.e. same g/box bell housing mounts as on the type 9 box so would it be a case of spacers?
Really any information on any of the above combos and what is needed for the 4AGE to RWD? Still new to the kit car scene so if i'm being think please excuse me.
Ive only recently joined and look quickly so if i'm repeating someone else's topic please forgive.
martin1973
posted on 16/12/07 at 07:12 PM Reply With Quote
zetec will fit on a type 9
martin
posted on 16/12/07 at 07:24 PM Reply With Quote
Have you ever been for a ride in a bike engined car (BEC) ??
Phil
focijohn
posted on 16/12/07 at 07:29 PM Reply With Quote
Is that with the clutch off the zetec?
No I've never been in a BEC
posted on 16/12/07 at 07:35 PM Reply With Quote
Try and get a ride in both a BEC and CEC before deciding which engine to install. I'm not saying you'd prefer the BEC but you need to get a ride in one before making your final choice of engine...
Whereabouts in the world are you?
Phil
bonzoronnie
posted on 16/12/07 at 07:41 PM Reply With Quote
BEC
The thought of a BEC is a little scary for me
I would imagine if I had a ride in one. I would quickly find out ------------
Adrenaline is Brown
Ronnie
posted on 16/12/07 at 07:49 PM Reply With Quote
You really NEED to get a ride in one.......
Phil
focijohn
posted on 16/12/07 at 08:04 PM Reply With Quote
Its not the speed that i was worried about but the drivability. I live on the Malvern Hills worcestershire and have heard stories of the torque and general user friendlyness, so i hadnt really even thought about it. what are they like on insurance and the cost of installing them?
More of a drivers car. each to their own i suppose.
John
[Edited on 16/12/07 by focijohn]
onzarob
posted on 16/12/07 at 08:07 PM Reply With Quote
Phil
Undaunted in the persuit of the BEC
I'm tending toward a 1600 engine, in my mind, then maybe upgrade later. This should give me chance to learn to drive the car without wrapping it around a imovable object.
Also I fancy doing some sprints/hillclimbs and want to be in the right class.
[Edited on 16-12-2007 by onzarob]
bonzoronnie
posted on 16/12/07 at 08:26 PM Reply With Quote
Be very affraid
Phil
But I know I would be frightened
Ronnie
matt.c
posted on 16/12/07 at 10:17 PM Reply With Quote
Boat anchor is always an option?
martin1973
posted on 16/12/07 at 10:40 PM Reply With Quote
yes zetec 1.8 clutch
try search on here lots of info about zetec to type 9
you do need a type nine from an inline engine ie not a v6
the 1.6 cvh is a cheap option tho as well normally come free with sierra donar and gives option of upgrade to zetec as well
martin
Canada EH!
posted on 17/12/07 at 12:29 AM Reply With Quote
Engine & Transmission
The 4 AGE is a good unit, the fwd unit requires a T50 Transmission. The bell housing, clutch, and slave cylinder bolt right on. There is a little extra work to plumb the rad. There is a chap in Australia who has done a magnificent job with info on the 4 AGE, he put one in a Ford Anglia
Volvorsport
posted on 17/12/07 at 12:39 AM Reply With Quote
volvo volvo volvo volvo volvo
5 cyl 5 cyl 5 cyl 5 cyl 5 cyl
www.dbsmotorsport.co.uk
getting dirty under a bus
bonzoronnie
posted on 17/12/07 at 09:21 AM Reply With Quote
Volvo "Nice"
How could I not agree to that
Top Tip
Ronnie
DarrenW
posted on 17/12/07 at 10:15 AM Reply With Quote
You wont often here me say this but Hellfire's advice is well founded. Any car is only fast if you put your foot down and having some potential can be a good thing. I loved my ride in BigRich's car, very surprised at how tractable the Z10 is. Im not converted to BEC but it defo has its uses.
bigrich
posted on 17/12/07 at 10:49 AM Reply With Quote
you still holding a torch for my baby mate
I would say think of how you want to use your car 90% of the time ,if this is 2 up trips into the countryside with the missus then a car engine is probably a more sensible option
BUT
If you want the full on ,light weight, high revving experience, and don't mind it being a little less forgiving then a BEC could be the answer. I would seriously recommend a spin out in both before you place an order just so your sure in your own mind
Rich
onzarob
posted on 17/12/07 at 04:16 PM Reply With Quote
Both these look like strolls in the countryside
BEC
CEC
HTH
[Edited on 17-12-2007 by onzarob]
focijohn
posted on 19/12/07 at 09:20 PM Reply With Quote
Any one live near me that could give me a ride in their BEC please?
onzarob
posted on 19/12/07 at 10:47 PM Reply With Quote
Me too I'm in Cornwall
locost_bryan
posted on 20/12/07 at 03:19 AM Reply With Quote
iirc that's Phil Bradshaw from Auckland, New Zealand. He also put one in a Leitch 7.
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
