Author: Subject: Making your own setscrews
takumi
posted on 21/12/07 at 03:51 PM Reply With Quote
Ive have a bit of a head ache finding..
Counter Sunk Socket Cap Set Screws in a M12x1.5 fine. (bell housing to gearbox)
My local fasteners specialist says no one makes them, and I could find anything online either..
So I had to modify some same head 'bolt', cut off the threaded part, and retap the blank shaft to a M12 fine thread.
All came out better than I hoped.. I had to heat them up a bit with a gas torch to help take off the hardness on the surface , as they were 10.9 rating !
well chuffed.
[Edited on 21-12-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
Ivan
posted on 21/12/07 at 04:37 PM Reply With Quote
Neat - justifiably chuffed
Alan B
posted on 21/12/07 at 08:42 PM Reply With Quote
I wish I'd have known...I have a box of those doing nothing......
not really...but someone usually comes along with that kind of offer....
Nice job, should work fine.
Alan
Confused but excited.
posted on 21/12/07 at 11:41 PM Reply With Quote
Give yourself a big pat on the back.
blakep82
posted on 22/12/07 at 12:21 AM Reply With Quote
lovely job!
________________________
chriscook
posted on 22/12/07 at 11:11 AM Reply With Quote
Are you intending to re-harden them?
nasty-bob
posted on 22/12/07 at 12:20 PM Reply With Quote
Did you try Stig Fasteners. I believe they will do specials aswell although they stock many types that are usually hard to get. I've used them and they were really good, quick delivery and the prices are pretty good too.
