Moorron
posted on 7/1/08 at 01:37 PM |
toe setting for rear suspension.
not locost related but you lot here know your stuff.
Im fititng an engine in the back of my renault turbo, i have used the front subframe of the same car in the back. So its mcpherson struts and a lower
wishbone.
This leaves me with the problem of the wheels turning as there is now steering rack at the rear. A friend told me i should aim to abtain 1-2 degrees
of toe in when the suspension compresses.
Is this true?
Comments please.
Sorry about my spelling, im an engineer and only work in numbers.
dan__wright
| posted on 7/1/08 at 01:41 PM |
we just my mates zcars mini last night, we put 0.5 - 1 toe out on it as the wheels will toe in when you put the power down.
FREE THE ROADSTER ONE…!!
worX
| posted on 7/1/08 at 01:59 PM |
^^^ Exactly!
Aico
| posted on 7/1/08 at 03:33 PM |
No troubles/unstability with braking with toe-out?
Bob C
| posted on 7/1/08 at 03:42 PM |
Follow the line from the middle of the damper through the pivots on the upright to the floor & determine your 'scrub radius'. If this
is near the middle of the tyre you should need very little 'toe'. If it's inboard then a little toe in would be indicated, depending
on the compliance of the joints.
Too much toe will wear out your tyres & knacker the wheel bearings.
Bob
Ians
| posted on 7/1/08 at 07:28 PM |
Any toe out on the rear is not a good thing...IanS
| posted on 7/1/08 at 07:55 PM |
Yes --- Quite a lot of toe-in otherwise you will visit the ditch a lot.
