New Topic New Reply
Author: Subject: mk headlamp bar
COREdevelopments
posted on 7/1/08 at 08:52 PM Reply With Quote
mk headlamp bar
Hey all. can anyone tell me the length of a mk headlamp bar?
thanks
Rob
whitestu
posted on 7/1/08 at 08:55 PM Reply With Quote
Not sure but it fits perfectly between my headlamps!
milton
posted on 7/1/08 at 08:57 PM Reply With Quote
head lamp bar
do you want overall or hole centres
milton
COREdevelopments
posted on 7/1/08 at 09:00 PM Reply With Quote
hole centre would be prefered,
thanks
posted on 7/1/08 at 09:02 PM Reply With Quote
800mm
Phil
COREdevelopments
posted on 7/1/08 at 09:05 PM Reply With Quote
thanks hellfire. and milton
oh and you too whitestu!:
atb
Rob
milton
posted on 7/1/08 at 09:08 PM Reply With Quote
bar
mine is 877 O/A and 830 hole centres you takes yer choice
COREdevelopments
posted on 7/1/08 at 09:11 PM Reply With Quote
are they both MK? only rough guide in need, thanks for the swift replies guys.
Rob
milton
posted on 7/1/08 at 09:17 PM Reply With Quote
bar
Yes mine is I stood and watched him make it
Milton.
posted on 7/1/08 at 09:46 PM Reply With Quote
Ours is MK too. Just go for somewhere between the two and you'll be fine.
Phil
omega 24 v6
posted on 7/1/08 at 10:31 PM Reply With Quote
WARNING
As you are building a Luego then you will also need to consider the fact that your headlights can be no more than 400mm from the most extreme outer edge of the vehicle to the edge of the light emitting surface. And as Luego's are supposed to be big wide bad boys it may become an issue for you at a later date.
COREdevelopments
posted on 8/1/08 at 11:10 AM Reply With Quote
mine is a luego locost chassis, using locostparts(MNR) wide wishbones, shall measure to see the difference.
thanks
rob
New Topic New Reply
