Author: Subject: Sierra CV joints Bolts
James
posted on 22/10/03 at 03:56 PM Reply With Quote
I'm about to put in 2 orders for the 24 bolts that pin the three parts of the 4x4 drive shafts together. Is there any benefit of buying Ford's Torx socket ones (52p) over AHC's allan key socket ones (19p)?
They're the same grade (12.9)?
Thanks,
James
theconrodkid
posted on 22/10/03 at 04:17 PM Reply With Quote
cheap is good
who cares who wins
pass the pork pies
ned
posted on 22/10/03 at 04:22 PM Reply With Quote
James,
As discussed, I'll be in for the allen key jobbies over the torx ones. Less tools to worry about...
Ned.
beware, I've got yellow skin
siert
posted on 22/10/03 at 05:09 PM Reply With Quote
i fitted the allan key ones aswell....12.9..and no problems...go for it.
TL
posted on 23/10/03 at 12:28 PM Reply With Quote
DOES ANYONE KONW IF THE BOLT-ON DRIVE SHAFTS CAN BE FITTED TO A DIFF WHICH WAS ORIGINALLY FITTED WITH PUSH-IN DRIVESHAFTS?
IN OTHER WORDS, ARE THE INTERNALS OF THE DIFFS IDENTICAL? FROM MEMORY, THE HAYNES MAUAL SHOWS THE BOLT-ON SHAFTS ARE RETAINED
BY A C-CLIP, BUT WILL THIS C-CLIP AREANGEMENT FIT A DIFF WHICH DIDN'T ORIGINALLY USE A C-CLIP?
CHEERS
TERRY
