Dougie T
posted on 9/2/08 at 08:21 PM |
Xr4i front hubs
Does anyone know if the xr4i front hubs are the same as standard ones i.e do they take the same ball joint etc.
scotty g
posted on 9/2/08 at 08:41 PM |
Yes they are the same, they tend to have the little hole in them for the ABS sensor, i welded a big dollop of snotty weld over it then ground it back
a bit to tidy it up, perfect!
mookaloid
posted on 9/2/08 at 08:44 PM |
i used Xr4i front uprights on my indy - the ball joints fitted no problem.
not sure if the hubs are the same as standard - I have a feeling that the bearings are bigger as are the brake discs.
Note the Xr4x4 are not the same.
HTH
Mark
scotty g
posted on 10/2/08 at 07:05 AM |
Oooops i missread that, i got mine of a 4x4 not a XR4i sorry dude.
NS Dev
posted on 10/2/08 at 11:07 AM |
4X4 has different front uprights, bigger hole for the strut to bolt into.
early type i.e. 2.8i XR4i uprights had the "taper with a nut on top" type fittings, 4x4's had the pinchbolt type, again not
interchangeable.
Dougie T
posted on 11/2/08 at 01:10 PM |
Another question to anyone that knows.
do the xr4x4 discs and callipers fit on the xr4i hubs or not?
NS Dev
posted on 11/2/08 at 11:43 PM |
iirc I don't think they do, seem to remember the lug offset on the mounts is different.
I have had both and tried interchaging them but I can't quite remember the outcome, other than I'm pretty sure it didn't work!
