Author: Subject: MotaLeira Dash and Paddleshift
nitram38
posted on 12/2/08 at 01:43 PM Reply With Quote
A little bit more!
Both to be anodised.
Dash will contain:
Dual spa oil/water gauge, Innovate lambda gauge, Savage push button switches, rotary light/indicator switches, Fia batt cut-off, Bright 6 indicator leds, Accumen gear indicator. (veypor dash on steering wheel).
[img][/img]
mad dad
posted on 12/2/08 at 01:55 PM Reply With Quote
wow that will look nice...........maybe you should make them and sell???
nitram38
posted on 12/2/08 at 02:02 PM Reply With Quote
They take too long.
Although cnc'd, it is the welding that takes time.
plus everyone will want different holes and housing shapes etc.
Originally I was going to get molds made and do the dash in carbon.
[Edited on 12/2/2008 by nitram38]
dan__wright
posted on 12/2/08 at 02:04 PM Reply With Quote
looking very good.
one thing, are you going to sva it? removedbale wheels need to have something to stop them being removed while the car is in use (eg raidhp on needs a key to remove it, fix that key to your ignition key and its not pissble to remove it while car is in use.)
FREE THE ROADSTER ONE…!!
nitram38
posted on 12/2/08 at 02:08 PM Reply With Quote
Originally posted by dan__wright
looking very good.
Not true. I have asked this already at sva of the F1-2. It passed no problem.
Mr Whippy
posted on 12/2/08 at 02:16 PM Reply With Quote
WOW! your not building one of these are you? Rescued attachment flash-gordon.jpg
nitram38
posted on 12/2/08 at 03:43 PM Reply With Quote
neilj37
posted on 12/2/08 at 04:08 PM Reply With Quote
Now that is sexy, I think I have just soiled myself
gingerprince
posted on 12/2/08 at 04:19 PM Reply With Quote
I think that with all the work that's gone into the dash, it seems a shame to just stick a Veypour to the steering wheel - seems somehow out of sync with the rest of the build.
IMHO of course - I would probably use selotape ;P
nitram38
posted on 12/2/08 at 04:53 PM Reply With Quote
The switches, fia switches have to go somewhere, so I designed the dash so that everything is inside of the 127mm projection rule.
When you sit in the car, everything can be seen, even the gauges, which can be viewed through the wheel.
If I added the veypor to the dash then the buttons on the lap timer/program changes etc would be further away.
I can hit a lap button with either thumb.
Apart from indicators and horn, most of the time my hands do not need to leave the wheel.
cloudy
posted on 12/2/08 at 06:28 PM Reply With Quote
PHWOAR! nice job
