Author: Subject: type 9 gearbox
Dave Bailey
posted on 16/2/08 at 12:38 PM Reply With Quote
type 9 gearbox
At the beginning of my build I had my gearbox rebuilt by BGH geartech with a long first fitted etc. A number if years later I have finally fitted the box and fitted the prop. The problem is that I can't spin the prop in neutral and if I manually turn the engine over the prop rotates.. Anyone had the same problem after leaving the gerabox standing for a while. I have had the cover off and no corrosion or anything. Any ideas? Last thing I want to do is have to take it apart!
thanks
Dave Bailey
theconrodkid
posted on 16/2/08 at 12:47 PM Reply With Quote
happened to mine.....but then it was full of water
make sure the baulk rings are free and not stuck on the hubs,a gentle tweak with a screwdriver may un-stick them
who cares who wins
pass the pork pies
Dave Bailey
posted on 16/2/08 at 12:53 PM Reply With Quote
Thanks.. All I have to do now is identify the bulk rings.....
Paul TigerB6
posted on 16/2/08 at 12:55 PM Reply With Quote
Its not the clutch thats stuck is it???
stevec
posted on 16/2/08 at 12:56 PM Reply With Quote
I would contact BGH for advice first before doing anything as you may void any warranty on the box by fiddling with it.
Steve.
Dave Bailey
posted on 16/2/08 at 01:03 PM Reply With Quote
To be honest I doubt I have any warranty left it was about 3 years ago it was done! However talking to them is probably a good idea...
thanks
Dave B
Paul (Notts)
posted on 16/2/08 at 02:27 PM Reply With Quote
Have you tried putting it in first and moving the car or turning the engine to free it up then working throught the other gears, before trying nuteral again.
or your sure its being put in nuetral by the gear linkage and not still in gear?
Paul
Dave Bailey
posted on 16/2/08 at 04:06 PM Reply With Quote
Pretty sure it is in neutral trouble is I can't rock the car backwards and forwards because I don't have the diff in yet but this will be the next check....
Dave Bailey
posted on 16/2/08 at 06:34 PM Reply With Quote
Still looking for more ideas on what this could be!
Schrodinger
posted on 16/2/08 at 08:57 PM Reply With Quote
I would speak to BGH first but how about locking the propshaft somehow and then turning the engine over on a spanner
Keith
Aviemore
Dave Bailey
posted on 16/2/08 at 08:59 PM Reply With Quote
agreed will call Brian on Monday.....
johnjulie
posted on 17/2/08 at 11:35 AM Reply With Quote
Talk to BGH first, in case you do any damage.
Cheers John
Dave Bailey
posted on 18/2/08 at 07:00 PM Reply With Quote
Well spoke to Brian (well Chris actually) and quite simple really.... If you sit in the car and pretend your driving it (you have to don't you) and change gear the bulk rings can all stack up one after the other. The action of the engine running drops the previous gear bulk ring during the change in normal operation. To get over it select reverse and then turn the engine manually.. Bob's your uncle I've got a neutral again.
magic... thanks to BGH Geartech
