Author: Subject: GSXR Injectors
DaveFJ
posted on 20/2/08 at 01:53 PM Reply With Quote
GSXR Injectors
OK... I know this has been done to death but...
I have searched on here and every other source/forum I can come across and yet i still cannot get a deffinative answer to a question that a LOT of perople must have faced!!!!
So please don't groan when you read the next bit - I know it's more repetative than the one about poly bushes but give it a go! and maybe if we get a deffinative answer it can become a sticky??
here Goes:
I have GSXR 750/1000 k2 throttle boddies. they are fitted with the standard injectors.
SO...
what is the flow rate of these? and are they high impedance?
I have found conflicting answers of 220, 240 and 270 for the flow rate (@3bar??) and no real answer on impedance...
I don't have any useful information like part numbers but here are some piccies:
Please only answer if you really do KNOW the answer.. the waters have been muddied enough already by people with only half a clue!
[Edited on 20-2-08 by DaveFJ]
Dave
JohnN
posted on 20/2/08 at 01:58 PM Reply With Quote
You don't say which size throttle bodies, are they from a 600, 750, or 1000cc bike?
The clue is in your avatar, I assume 1000cc !
[Edited on 20/2/08 by JohnN]
nre
posted on 20/2/08 at 02:08 PM Reply With Quote
Well, the only way to resolve this is to find someone who has had one tested. My website quotes 270 for gsxr750 as that was the figure I dug out from somewhere or other on the web. My injectors run a 1.8 zetec using a 2.5bar regulator at about 85% max duty cycle, so should be fine on a 3bar regulator for a 2.0 zetec or similar.
They are definitely high impedance - my emerald ECU drives them directly with no issues.
[Edited on 20/2/08 by nre]
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
DaveFJ
posted on 20/2/08 at 02:09 PM Reply With Quote
Ooops... corrected!
Dave
muzchap
posted on 20/2/08 at 02:29 PM Reply With Quote
Are they KEIHIN ones? They are good for 190bhp and flowed well enough at 3bar for my 160hp Zetec.
The next upgrade is either S2000 or Blackbird injectors which I believe are pretty good upto around 350hpish
I think they are the same impedence as Zetec injectors.
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
piddy
posted on 20/2/08 at 03:36 PM Reply With Quote
600 GSXR are 230cc so should be higher than that.
vinny1275
posted on 20/2/08 at 03:48 PM Reply With Quote
I've managed to find a GSXR1000 workshop manual which should have this in it (I'm fitting the same tbs). I'll dig it out ( I think it's on my old laptop), and find the info for you.
vince
chriscook
posted on 20/2/08 at 06:21 PM Reply With Quote
I suspect it may be different for different vintages. Some of the Megasquirt firmware versions have a test mode so you can measure them yourself.
trikerneil
posted on 20/2/08 at 06:42 PM Reply With Quote
Have a look HERE for GSXR injector info
HTH
Neil
ACE Cafe - Just say No.
posted on 20/2/08 at 07:03 PM Reply With Quote
Only takes a few seconds to measure the impedance with a multimeter. Can't help with flow rate , sorry
GregSL75
posted on 20/2/08 at 10:31 PM Reply With Quote
DEFINATELY high impedance on the GSXR1000, I have used Flow Rate of 230cc/min in my calcs and it's mapped and racing now.
2.0 XE on GSXR TBs and Megasquirt
