Author: Subject: Velocity body height
craig_007
posted on 21/2/08 at 09:25 PM Reply With Quote
Hi all,
I have just recently fitted mt velocity body panels to my car,They do infact seem to be a good bit taller than most of the other body panels !!
My question is regarding seating position and body height,When I sit in the drivers seat I cannot see the nose cone or the passenger side wheel arch,Am I needing to raise the seat or is every velocity much the same.I would have thought for driving(trackdays) It would be far better if I could see right down the nose of the car !!!
Any thoughts ????
[Edited on 22/2/08 by craig_007]
Johnmor
posted on 22/2/08 at 06:57 AM Reply With Quote
Ride height
I have a viento and that seems to be the same , can't see the nearside wheel arch or front of nose cone.
Is the top of your head below the role bar when seated? I think that would be the important bit for me, add an inch or two for gravity when inverted and see if you can keep your head when the chip are down!!!
kitcarkris
posted on 24/2/08 at 09:03 AM Reply With Quote
are you using seat runners or are you just bolting the seat stright down??
