Author: Subject: finding an ip addres
k33ts
posted on 23/2/08 at 09:51 AM Reply With Quote
is there a way to see someones ip addres on a forum,
unless theres another way to find out if two users are the same person.
cheers
tukcustoms.com
tks
posted on 23/2/08 at 09:54 AM Reply With Quote
well infact yes there is...
but on the downside only the Admin could lookup the logs and see who is who....
Tks
Dangle_kt
posted on 23/2/08 at 11:17 AM Reply With Quote
Also some ISP's provide what are called dynamic IP addresses, so that each time you log on you get a different IP.
If the two people/one person did not have a static IP and had switched the PC off between posts, it still may not show up.
hobbsy
posted on 23/2/08 at 01:55 PM Reply With Quote
Dynamic IP's dished out on ADSL accounts aren't always that dynamic, a lot more people are running routers that are always connected rather than connecting on demanding with a USB modem for example so less likely to change.
